Is there any interest in a new Y-Block valve cover design?
Posted By Ted 19 Years Ago
1
4
5
6
7
8
9
f-100 bob
Posted 19 Years Ago
Last Active: 16 Years Ago
Posts: 18, Visits: 203
Thanks Guys;   The designs are all great hard to pick from,  I myself have been a F-100 guy since the late seventies,  any of the covers would look great on the 54 panel I'm building,  just got a 272 with 3 pots,  it already has crome valve covers  but would like a Y - Block design to really set off the look .   I would be happy with either a decal  or  new cover design  count me in just let me know what the finish unit would look like ?   thanks  F-100 bob
 F-100 Bob -  Brainerd ,  Minn.
Posted 19 Years Ago
Chuck's solution might be the best. The more detail that is added to the top, the more chance for error. Results in higher scrap rates and more cost.
pcmenten
Posted 19 Years Ago
Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)Supercharged (381 reputation)
Posts: 375, Visits: 1.1K
I just pulled apart another 292 today. It was a low-mileage rebuild. I'll save the description of the goof-ups that I found for a later thread, but I was thinking about the valve covers as I pulled the exhaust manifolds off.
I mentioned before that it would be nice to have bosses for four valve cover bolts and I have another reason for that concept; I'd like to put some heat shields over the valve cover to protect the valve cover gasket and to reduce the heat transfer to the oil. I can mount the shields with two bolts, but four would be better.
Best regards,
Paul Menten
Meridian, Idaho
Posted 19 Years Ago
Posts: 3.7K, Visits: 323.8K
Ford big trucks used to have heat shields incorporated in the exhaust manifold gaskets.  Stamped steel gaskets with pressed in beads around the ports, and a shield that extended upward to do exactly what you are thinking of.  I don't know if they are still available anywhere.
John
Glen Henderson
Posted 19 Years Ago
Posts: 1.4K, Visits: 7.5K
The last time I checked with NAPA, they were still available. You have to get them to look up gaskets for a big truck thought as John said.
Glen Henderson
Freedom is not Free
Letohatchee, AL
GREENBIRD56
Posted 19 Years Ago
Posts: 1.7K, Visits: 102.7K
Take a quick look at page one of the Jet-Hot Coating thread over in "This and That" .......Ted's 272 looks to have the truck shields in place.
Would there be an advantage for detailing or maintenance if they came off with the valve cover? Could be......If the casting just had the necessary "boss" cast down on the lower lip of the cover it wouldn't be too hard to finish them - or not. Some stainless sheet would make some neat removable shields.....
Posted 19 Years Ago
Posts: 4.6K, Visits: 39.5K
Agreed, but they would look good in stainless! Chuck
Posted 19 Years Ago
The valve cover decals are do-able but to make them heat resistant and super sticky to survive under hood conditions they will probably cost $10 to $15 a pair. Maybe a bit more. That would be in full color and cut to shape though. You guys still want them? My initial investment would be high to have the minimum printed. Chuck
f-100 bob
Posted 19 Years Ago
Yes Sir;  I sure do would look nice !!    still seems fair enough for a price.  F-100 bob
Glen Henderson
Posted 19 Years Ago
Chuck, I will take 6 sets to start with and will be glad to pay up front. Just let me know what the total will be. Thanks
Glen Henderson
Freedom is not Free
Letohatchee, AL
1
4
5
6
7
8
9
