292 valve adjustment
Posted By 1960 Edsel 292 16 Years Ago
1960 Edsel 292
Posted 16 Years Ago
Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)
Last Active: 15 Years Ago
Posts: 41, Visits: 80
guys,
my buddy with the 1960 edsel running the factory 292 engine is going to have another buddy adjust the valves.
what are the lash measurements for the intake and exhaust valves ?
and he FINALLY got around to having the trans pan dropped and filter cleaned. said it was very very dirty. put it back together and that seems to have cured all of his 1-2 slipping. said it shift nice and hard and he can now jump right on the throttle and not have to baby it when its ready to go into second gear.
and he pulled the holley 2bbl carb apart looking at the power valve, and the previous owner or someone really screwed things up, something about the locating pins for the metering plate were sheared off in the carb body, and the metering plate had hair line cracks all over it. so we think that is where he has continued to get the 40-60mph slight hesitation, and ordered a new carb. will have it here mid week, and he should be on his way to a nice running car.
then it will be onto the power brake conversion...
thanks guys
leonard
rick55
Posted 16 Years Ago
Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)
Posts: 550, Visits: 4.4K
Every method is talked about in Post #45824.
I like the 1/4 turn method as it takes into account the wear on the rocker arm face.
Regards
Rick - West Australia
1960 Edsel 292
Posted 16 Years Ago
thanks.
i tried posting for Post #45824 but it wouldnt show up.
so, are they hydraulic lifters with 0 lash ?
someone once told me they were solid lifters....
thanks
leonard
rick55
Posted 16 Years Ago
The litters in a block are solid.
Enter the post number I gave you earlier in the search box and press return it should come up.
Regards
rick55
Posted 16 Years Ago
Further to what I put in earlier go to search and type in setting the valves. There is a good deal of info in that post.
Regards
Posted 16 Years Ago
Posts: 3.7K, Visits: 323.8K
In answer to your question, the lash is .019, intake and exhaust.  Hot or cold doesn't make enough difference to worry about.
Posted 16 Years Ago
Last Active: 27 minutes ago
Posts: 3.8K, Visits: 33.3K
Hey Rick! 45824 does not bring up that post.I tried it.
speedpro56
Posted 16 Years Ago
Posts: 1.3K, Visits: 9.2K
The method I use is when the exhaust just starts to open adjust the Intake as John said too .019 , then when the Intake just starts to close adjust the exhaust too .019 as well.
-Gary Burnette-
Posted 16 Years Ago
Here’s the link to the aforementioned post.  I couldn’t get to post #45824 by doing a search either.
Setting the valves
crenwelge
Posted 16 Years Ago
Posts: 512, Visits: 1.7K
I have been setting valves with the engine running at a slow idle for over 50 years on both Y-Block and GMC. Is there any particular reason that anyone knows of as to why this is not an accurate way of setting them?
Kenneth
Fredricksburg, Texas
