Visits: 323.2K
Took the car to the track today to try the head gasket again. Never unloaded the car. Rain. I'm not too bummed, we despately need the rain here.
Visits: 1.5K
reckon you 're getting what just finished with us john. since last monday rain guage has recorded 22in. here. we needed it too,so know how you feel.
Visits: 323.2K
Now for the rest of the saga. Took the car to the track Saturday. Went 12.03 and 12.07 in my only two time runs. Both at nearly 112 mph with a stiff side wind. Lot of cars there, and first round was about 9:30 pm, I knew it would pick up. Dialed it 11.99, and on a double breakout race I ran 11.86 and 114+ to lose. All seemed well with the car. Sunday I got the bright idea to check my radiator catch can. It had considerable water in it. Today I ran a leakdown, and #1 (the problem cylinder at Columbus) and #3 each showed a very small leakage into the cooling system. Checked the bolt touque, they had relaxed. After the re-torque I re-checked #1, same result, so I drained the water and aired up the slicks for its long winter nap. I'll build another block this winter. Something's going on with this one. I'll use it someday on a NA car, I would be comfortable with that.
Could it just be time to replace the bolts?
Visits: 323.2K
Charlie: Good point, but the left side bolts are the same age, and there is no problem on that side. They are 1/2" grade 8 bolts.
