Bonneville Speedweek
Posted By mctim64 16 Years Ago
Y block Billy
Posted 16 Years Ago
Posts: 1.6K, Visits: 5.2K
I forgot one question, Isn't Karol Miller up in your neck of the woods, Maybe you should have invited him out there with you, I think he had the valvetrain figured out.
55 Vicky & customline
yfreak57
Posted 16 Years Ago
Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)Supercharged (103 reputation)
Last Active: 7 Months Ago
Posts: 100, Visits: 1.0K
Tim, on Youtube video from Bonneville your shifts were better than El Mirage. Was there some problem in linkage or was it between bench and steering wheel? Tongue
-jyrki from Finland-
www.hollowheads.net
mctim64
Posted 16 Years Ago
Posts: 2.4K, Visits: 5.0K
I tried to answer some of the questions but got locked out. w00t  Here's the video anyway.
http://www.youtube.com/watch?v=fctwQghNPu0
Posted 16 Years Ago
Posts: 3.7K, Visits: 323.8K
Billy:
I seem to remember gm using a 262 inch V8 in the glorified vega called a monza.  Wouldn't be too hard to destroke that one to 260.
mctim64
Posted 16 Years Ago
I'll try posting again now. Tongue
The chebbie was a 267 block (3.5" bore) and a 327 crank (3.25" stroke)  for a total of 254ci.  He showed me his dyno sheet and the #s were a little better than what we brought to the table but he was also running a TH-400 so both Charlie and I figured he might have trouble pulling that.  Apparently the extra stroke and torque helped and now he has the record and we have to beat 127 mph instead of 126.  Nothing worthwhile is easy. Wink
Posted 16 Years Ago
Any idea what heads he used? There can't be a big aftermarket for the 267.
GREENBIRD56
Posted 16 Years Ago
Posts: 1.7K, Visits: 102.7K
Charlie is on the right track - that little 3.50 bore size has to be close to the intake valve? Those scrub heads must be pretty interesting castings.....
Burns Brothers Racing ...
Congrats to all of you that had a hand in this, for both making the trip and then making a serious try at the record - and repairs to boot. If it was easy  - everyone would be able to do it - and we all know that's not the case. Better luck next time!!
mctim64
Posted 16 Years Ago
You're right, he couldn't run aftermarket heads he had to run the stock heads with 1.84" intakes and 1.31" exhaust, I guess big valves aren't what you need in a little motor.  The place where he put the real money was in pistons and rods, he got quite a bit better compression than we did with our flat top pistons.  That's why I'm talking with Ted about something better for our engine.
Y block Billy
Posted 16 Years Ago
Ok enough about him, Back to my first questions, any ideas on why the cam was going out?
Park Olson
Posted 16 Years Ago
Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)Supercharged (140 reputation)
Posts: 102, Visits: 1.9K
 God try Tim, ,,next up, killer motor in a Uniboby should be good for 135+,,,,BigGrin
