Visits: 188
They are expensive because it has title(very important like a house title) and no much A models are remaining with all the papers. Machine work for the engine also become expensive. The cam is an aftermarket one but the owner does´nt explain a bit of nothing about that cam. Anyone want a Phase 2? if y you can cost the shipment please let me know
Last Active: 8 Months Ago
Visits: 7.1K
Highvoltage, You seem to know the fase 2 engine, are the blocks the same as the fase 1 engines? I just wondered if the cam lifters are the same. Thanks for the information on the fase 2.
Gary Ryan San Antonio.TX.
Visits: 188
The block are the same. Lifters are the same solid lifters. the cam only changes the valve position as an SBF. Firing order is the same. Teh only difference are the cylinder head bolts which are a little big in diameter. I don´t know the exact size. Let me see, I have some at my shop.
