mctim64
Posts: 2.4K,
Visits: 5.0K
You even got a Ford alternator on it.  Looks like the engine may have been swaped at one time, you have the wrong front motor mount. If you like maybe Charlie has another pass. side manifold for you, just to give it a cleaner look without that patch on the old one.
bloodyknucklehill
Last Active: 14 Years Ago
Visits: 2.2K
Yeah i think it's a C2AE engine.. I had to point that out to the guy I bought it from when he gave me the whole, "I think the motor is from a T-Bird" story.. It's kinda funny though cause he tried to tell me it was from a 62 T-Bird
DustinSouthern Oregon Y's Guy  http://www.facebook.com/?ref=home#/profile.php?ref=profile&id=1441322018
yalincoln
Visits: 4.8K
hi, that extra manifold is for a 54 merc.
bloodyknucklehill
Visits: 2.2K
K so i'm coming up with nill looking for floor pan patch panels for this thing.. I can find the cab corners all day long but no floor pans.. Anyone know of a place that has em?
kevinwalshe
Visits: 251
bloodyknucklehill (7/6/2010) K so i'm coming up with nill looking for floor pan patch panels for this thing.. I can find the cab corners all day long but no floor pans.. Anyone know of a place that has em?This company has the floor pans you are looking for. Check them out. http://www.classicfabrication.com/
Loving my Y!
Kevin Walshe
Costa Mesa, California
bloodyknucklehill
Visits: 2.2K
bloodyknucklehill
Visits: 2.2K
Pulled the valve covers off the other day.. Wasn't expecting everything to be this clean under there..
Honestly i can't believe this engine has sat for twelve years.. I think i'm just gonna replace the plugs and wires and see if I can fire it up..
mctim64
Posts: 2.4K,
Visits: 5.0K
Might change the oil too!  Looks good.
bloodyknucklehill
Visits: 2.2K
yeah i should probably do that too  My plan is to drain the current oil, then throw a couple bottles of Marvel Mystery Oil into it and let that run through it, drain that out then replace the plugs, wires and points and see what happens.. Oh and check the PCV valve too (Thanks for the tip Tim).. Taking stock of some other stuff the brakes need a total rebuild and I need to find the correct factory steel wheels for it.. the two on the front were right but the rears are 16" white Mojocks with huge tires on them and it looks stupid..
kevinwalshe
Visits: 251
Mine didn't run for over 17 years and with a little work and some new parts, she fired right up. Before you fire it up, remember to prime the motor by removing the distributor and spinning the oil pump, that way the valves and cam don't run dry. Did you end up ordering the patch panels for the floor?
Kevin
Loving my Y!
Kevin Walshe
