The Y has been given an Alternate position in the EMC Challenge.
Posted By Ted 18 Years Ago
Posted 18 Years Ago
John,
            I actually have a matchplate for the Y stands now. Never thought about Iron.
Posted 18 Years Ago
Posts: 3.7K, Visits: 323.2K
Frank:
I was just being silly, didn't know you had worked on them.  Are Y stands that hard to find, or does John just want to be able to supply new ones with rocker assemblies?  Does Dove make stands to go with his arms?
John
Posted 18 Years Ago
Hoosier Hurricane (6/1/2007)
John.  Dove only supplies the aluminum 1.6:1 roller tipped rocker arms for a Y as well as a spacer kit to eliminate the springs.  It's up to the end user to come up with shafts and stands when using the Dove rockers.
56 Vicky
Posted 18 Years Ago
Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)Hitting on all eight cylinders (5 reputation)
Posts: 5, Visits: 75
Ted,
Give Jim Barillaro a call 865 609 1217 (Tennessee) He was using 7 rocker stands per head on his Y Blocks.
Cheers
Trevor
Posted 18 Years Ago
Thanks Trevor.  I'll give Jim a shout.  Sounds different and interesting.
Posted 18 Years Ago
John, Was going to use them in conjunction with  the higher lift rockers. Project died. Be easy to convert them to iron and raise the height.
                                                               Frank
