John, what you say makes sense.
Having just a little "working" knowledge of these things can definitely lead to false conclusions. So, I assume that the blower pulley itself has enough tension/pressure on its actuation (closing and opening, going from large diameter to small diameter) from the drive inside the housing, that the tension on the spring pack really plays no role in its movement, etc.
Therefore, I would also assume from what you are telling me that I need to get a belt that will fit the unit as close as I can get the spring pack to compress...upon initial installation (allowing for the minimum diameter of the blower pulley to have good friction on it because the spring pack is still holding it snugly around all of the pulleys in question)...now that's a mouthful!!
I will check out Chuck's belt first and go from there.
Daniel JessupLancaster, California
aka "The Hot Rod Reverend"
