Park Olson
Visits: 1.9K
Bob's 55 (5/1/2010)
Yes I had a '38 PU with a hand throttle and hand choke. Not to change the subject, but it also had a locking steering column... And yes it was stock Ford cars had locking columns 'till '47.
Unibodyguy
Last Active: 14 Years Ago
Visits: 848
My 52 F-2 pickup that I got from my Grandpa had a hand thottle on it from the factory, I used it a ferw times for loading up hay bales as mentioned in an earlier post. And also to hand pick sweet corn too.
MichaelSandy Valley, NV
46yblock
Visits: 7.8K
My 54 1 ton had a dash mounted hand throttle. I used it as an ancient cruise control. Problem was max. highway speed. 45 mph and around 4500 rpm.
DANIEL TINDER
Posts: 1.8K,
Visits: 154.7K
46yblock (5/4/2010) My 54 1 ton had a dash mounted hand throttle. I used it as an ancient cruise control. Problem was max. highway speed. 45 mph and around 4500 rpm.Still curious about it's operation: Ratchet & twist-release? Friction hold? Any drag on the carb. linkage? If not, what mechanism was used to hold position and avoid drag?
6 VOLTS/POS. GRD. NW INDIANA
46yblock
Visits: 7.8K
DANIEL TINDER (5/4/2010)
46yblock (5/4/2010) My 54 1 ton had a dash mounted hand throttle. I used it as an ancient cruise control. Problem was max. highway speed. 45 mph and around 4500 rpm.Still curious about it's operation: Ratchet & twist-release? Friction hold? Any drag on the carb. linkage? If not, what mechanism was used to hold position and avoid drag? Its operation from inside cab was just like a manual choke. The further you pulled the knob out the faster the engine would run. When pushed all the way in engine idled normally and foot throttle functioned normally. It was a long time ago so cant be much help. Using it as a "cruise control" wasnt very safe, and it took a fair amount of push/pull effort to operate the hand throttle.
crenwelge
Visits: 1.7K
The old throttle cables were identical to choke cables in most vehicles. Friction would hold them. They were only made to warm an engine or to drive a PTO. Even at that, they would not hold a constant rpm. On vehicles that required a constant PTO speed we used to install a Pierce governor. They are still being manufactured. A Pierce governor could be used as a cruise control. A cable type throttle like trucks had in the 40's and 50's was actually pretty worthless and thats why they discontinued installing them.
http://www.piercelockcraft.com/speed-control-devices/mechanical-governors.php
Kenneth
Fredricksburg, Texas
unibody madness
Visits: 1.7K
The older fords came with Chandler Grove 94 carbs, then with the holley 94, used today for multiple carb setups. I think there were close to 19 versions of this 2 barrel carb.the older ones came with choke ,normal accelerator, and hand throttle.This was set up on the opposite side of the throttle shaft and could be set like a hand choke. the foot pedal could accelerate past the point where the hand throttle was set, but would not cancel out the hand set throttle to lower it. I believe they were in fords in the fourties or even until the early 50's in some truck applications.You can buy new reproduction 94's today for about 150.00
montego_gto
Visits: 150
While growing up, my neighbor had a mid-70's, 400M equipped, Ford LTD- actually whatever the low trim level version was called. It was an ex-cop car. It had holes all over the interior where stuff had been previously installed. The car had a cable pull located just to the right of the steering column. When a cop would let the car sit idle with the engine running, they would raise the rpm's to keep it cool. Gary used it as a cruise control only a couple times since it didn't adjust for hills and it wouldn't automatically kick off. Nick
'60 F100 with '62 4V 292 y-block
Glen Henderson
Posts: 1.4K,
Visits: 7.5K
Anyone that was in the military (all branchs of the service had them) should remember the M35 2 1/2 ton truck and the M54 5 ton truck. They both had throttle cables, we use to run conveys with the throttles pulled out. Not the smartest thing to do, but who ever said that we were smart back then.
Glen Henderson
Freedom is not Free
Letohatchee, AL
glrbird
Visits: 7.1K
One of my friends had a hand control throttle on his car, it was a bar mounted on the steering column with a motorcycle type twist grip at the end and had a rod that ran from it and hooked to the top of the gas peddle. worked great. You just twisted it like a motorcycle throttle and when you let go the carburator return spring brought it back. you should find something at the conversion center.
Gary Ryan San Antonio.TX.
