5 speed
Posted By wrencher52 16 Years Ago
slick56
Posts: 460, Visits: 4.5K
Cheers Charlie Brown, terrific website + heaps of great information.
I have asked the question re. the Tremec part no., something i didn't consider was type of speedo drive, electronic or gear,
also of concern is a forward mount shifter to clear the split bench.
I have 205/75-15 tyres, 3.70 gears 9"
This is a fantastic forum, there appears to be an answer to everything!
Thanks again,
Al.
South Australia
Rono
Posts: 1.3K, Visits: 80.0K
Slick56;
I remember the trial and error process with my T-5 trying to get the correct driven gear for my Haneline (no longer in business) speedometer. On my current build, I am seriously thinking about this new technology "Sky Drive" that uses GPS for calibrating your speedo. There are several companies making them and they average about $200, but may be worth eliminating the hassle. Here is an example of Auto Meter's device that is universal. http://www.autometer.com/media_newsarticle.aspx?yr=2012&mo=3&aid=124
Rono
The Master Cylinder
Posts: 974, Visits: 6.2K
Rono (10/6/2013)
Slick56;
Rono
Or if you don't already have a speedo you could get a GPS Speedo like the units from Speed Hut for not much more than the Auto Meter Interface... http://www.speedhut.com/gauges/GPS-Speedometers-Gauges-Only/1:3|39:1/i=12&p=5 You can even customize the face if needed/wanted. The one I'm interested in matches my SW oil an temp gauges pretty closely.
Last Active: 10 hours ago
Posts: 4.6K, Visits: 38.5K
I've been using the Speedhut GPS speedo in the roadster all summer. Works great! With this setup you don't have to worry about calculating tire size or gear ratio. You can change all you want. I just put a set of "custom" Speedhut gauges in a new dash for the roadster. Very nice set and very easy to setup. They come with plug in connectors from the gauges and senders. Its even possible to take the gauges out of their cans and use them without the bezels or cups. I had them make two of the gauges 90degree bottom sweep at very little additional cost. I didn't intend to rave on one company quite so much but they have been excellent to deal with. Chuck
lyonroad
Posts: 703, Visits: 3.1K
I have 2 T5 Z code 5 speeds that I got from Modern Driveline in Boise. One in my 56 pickup behind a 351C and the other to go in my 55 Fairlane behind a rebuilt 292. The pickup drives and shifts like a dream. Modern Driveline can provide everything you need - adapters, yokes, speedo driven gears, shifters, clutches - both 10 and 11 inch etc.
Mark
1956 Mercury M100
1955 Ford Fairlane Club Sedan
Delta, British Columbia
The Master Cylinder
MoonShadow (10/6/2013)
Chuck, Thanks for the review on the Speedhut GPS Speedo. Don't worry about the "rave" It's good to hear you liked them so much. That's how the rest of us find out whats good or bad.
Since I want to keep my '55 Ranchwagon's dash stock in appearance I was looking at getting a 2 1/16" Speedhut GPS speedo to 'back up' the original and install it in a under dash gauge mount. With their customizing feature it looks pretty close to my SW oil and temp gauges... Not exact, but close.
http://forums.y-blocksforever.com/Uploads/Images/d8950fd9-12e1-4fdb-82d6-7142.png
That would work. Amazing how much the customized gauge looks like the originals. I have a 56 dash cluster that I put SW gauges in but hadn't done anything with the speedo. I think, in the spring, I will get a Speedhut GPS unit to fit. I also like the simplified mount using a screw collar on the back to tighten the gauges in the panel. Chuck
