Rear Disc Brakes
Posted By 55Birdman 16 Years Ago
yehaabill
Posted 16 Years Ago
Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)
Posts: 426, Visits: 1.4K
Birdman Y-Guy:         You might look into '93-up Explorer with 8.8 disc set-up.
                    Cheap,at the local pull-apart, width should be close, and its leaf
                    spring  also. May have to change M/C.....
                                               Just an idea,
                                                  Bill
Bill
Pelham,Al
55Birdman
Posted 16 Years Ago
Posts: 1.0K, Visits: 4.5K
I have discs on the front. Will look into the explorer brakes. Thanks Bill
55Birdman Smile  Hickory NC
Posted 16 Years Ago
Posts: 1.9K, Visits: 194.9K
I put rear disc on my bird, Dana rear end, about 5 years ago. It was way more trouble than it's worth. There's a shop in Denver, I can look it up, where they did a set for the owner's car. They used the early GM units with the built in parking brake on the disc itself, and built a bracket to mount it to the axle. What they forgot to tell me was that that unit requires a 10 psi residual valve, not a 5 like most disc. I went thru everything twice before I finally got brakes. It was American Braking Systems (I think it its abspowerbrakes.com) that finally said "Oh yeah, those are the one's you need drum brake residual valves on". Unless you've got big tires and are going road racing, I wouldn't bother.
morgus
Posted 16 Years Ago
Last Active: 14 Years Ago
Posts: 31, Visits: 1.3K
I HAVE A 55 BIRD WITH REAR DISC--DID THIS IN 2003--WORKS GREAT--I HAVE 20 OR SO PHOTOS OF WHAT NEEDS TO BE DONE TO DO THIS---THE REAR IS A DANA 44 'HYBRED' (CENTER SECTION IS LIKE COMMON MO-PAR UNIT) BUT THE AXLES AND BEARING ENDS ARE FORD TYPE---BIRDS USED THIS REAR IN 55 AND 56 --57 WENT TO FORD 9 INCH--THE KIT I USED WAS FROM MASTER POWER BRAKES CO.--ORDER THE KIT FOR A JEEP CJ-5, I THINK---THEY MAY ASK YOU TO SEND PHOTOS OF YOUR END FLANGES--I ALREADY HAVE DONE THIS --I HAVE THE PHOTOS OF THIS FLANGE---YOU WILL ALSO HAVE TO CHANGE THE MASTER-AND ADD A PROP VALVE--MASTER HAS THIS ,TOO---I WENT TO FOUR WHEEL DISC'S SO I CAN'T TELL YOU WHAT MASTER TO USE--MASTER PWR KNOWS---E-MAIL ME IF YOU WANT INFO---morgus@accesstoledo.com ------I'M IN TOLEDO OHIO----ED----419-377-9449 -------WITH THIS KIT--EVEN THE EMERGENCY BRAKE CABLES MATCHED UP AND WORK FINE----BYE----ED
55Birdman
Posted 16 Years Ago
what year cj-5? send photos . sent e-mail.
Posted 16 Years Ago
Birdman: Unless you have money to burn, lots of patience & are road racing your car, I doubt that the conversion is worth the effort & expense. As a possible alternative, I believe MP brake has a drum conversion kit that feature ceramic linings, that may fit your car. Obviously, it's your call however..
55Birdman
Posted 16 Years Ago
MP brakes has rear disc kit for 750.00 went down there and looked at all kits available and purchased the disc kit. They are installed and doing well so far. Its nothing but money.....
morgus
Posted 16 Years Ago
stock 55 and 56 birds are dana 44's--ford style---57 bird are 9 inch ford---when i went to 4 wheel discs on my 55 bird in 2003, i used the kit for a jeep c-j 5 or cj-7----this worked--but i had to shim out the caliper mount a tad to put it in the center of the rotor. unbeleivably--the emerg. brake cables hooked right up!!!!--- i went with billet wheels--15 inch--and everything clears--don't know if it will on 14 inch rims........bye EDDIE
Posted 16 Years Ago
Last Active: 1 hour ago
Posts: 3.7K, Visits: 497.8K
Who's kit???
morgus (9/14/2009)
