Y-block marine engines
Posted By Hollow Head 16 Years Ago
Hollow Head
Posted 16 Years Ago
Posts: 1.0K, Visits: 3.8K
Don't know or remember if anyone has added this link here, but here it is Smile. Discussions about Interceptor marine Y-blocks.... and other Ford marine engines too...
http://www.marineengine.com/discus/messages/12513/12513.shtml
Threaded View
Threaded View
Forum Post Y-block marine engines By Hollow Head ( 16 Years Ago )
Forum Post More about those engines...... By Hollow Head ( 16 Years Ago )
Forum Post there used to be a boat building business in my area".Leecraft" they... By montana ford man ( 16 Years Ago )
Forum Post Some Y-block boats...... By Hollow Head ( 16 Years Ago )
Forum Post [quote][b]Hollow Head (4/29/2009)[/b][hr]Some Y-block boats...... By mctim64 ( 16 Years Ago )
Forum Post I have a 63 marine short block in my truck. The water jackets were... By Doug T ( 16 Years Ago )
Forum Post Some marine engines run backwards, which won't work in a car. I think... By Hoosier Hurricane ( 16 Years Ago )
Forum Post More boats with Y-blocks... nice :)... By Hollow Head ( 16 Years Ago )
Forum Post most marine engines were 292's , the intakes are a little small ,but... By mongo ( 16 Years Ago )
Forum Post [quote][b]mongo (4/30/2009)[/b][hr]most marine engines were 292's ,... By mctim64 ( 16 Years Ago )
Forum Post Tim and guys, i can add a story on one of these interceptor boats,... By aussiebill ( 16 Years Ago )
Forum Post Tero found something interesting from graigslist :)... By Hollow Head ( 14 Years Ago )
Forum Post That was on Slick 60's site. By Teros292 ( 14 Years Ago )
Forum Post Just by coincidence there is a seller on Kijiji in my area parting... By oldcarmark ( 14 Years Ago )
Forum Post Those could work ok in stock daily driver, but might be small on Hot... By Hollow Head ( 14 Years Ago )
Forum Post That is excactly the setup being offered for sale.I am thinking about... By oldcarmark ( 14 Years Ago )
Forum Post The carbs are 1bbl and the same as the Blue Flame vetts. Not big on... By MoonShadow ( 14 Years Ago )
Forum Post I see the hose on each side going to the water manifolds.What would... By oldcarmark ( 14 Years Ago )
Forum Post You would need a y connector like Smokey Yunnick used to make. Or... By MoonShadow ( 14 Years Ago )
Forum Post Thanks! He has the valley pan also included with the intake price.Is... By oldcarmark ( 14 Years Ago )
Forum Post More info from the seller on Kijiji.The motor was destroyed and... By oldcarmark ( 14 Years Ago )
Forum Post Its not uncommon to find good heads on these boat motors. Check them... By MoonShadow ( 14 Years Ago )
Forum Post you will also have to have the special valley pan to clear the bottom... By ecode ragtop ( 14 Years Ago )
Forum Post Well, this is something to fall in love with ;)... By Hollow Head ( 14 Years Ago )
Forum Post Very nice.Those intakes are aluminum.Would look real sharp polished... By oldcarmark ( 14 Years Ago )
Forum Post Mark, those sidedraft Carters are the same carburetors as where used... By The Master Cylinder ( 14 Years Ago )
Forum Post I just got back back from checking out the marine stuff.The heads are... By oldcarmark ( 14 Years Ago )
Forum Post I never looked into the boat Mallory's but do they have a centrifical... By MoonShadow ( 14 Years Ago )
Forum Post I am not interested in the oil pan etg.Just thought it was interesting... By oldcarmark ( 14 Years Ago )
Forum Post Parts are now listed on Ebay under "Ford Y Block".He is asking a lot... By oldcarmark ( 14 Years Ago )
Forum Post If your not in a hurry I would wait a while. Check older local boat... By MoonShadow ( 14 Years Ago )
Forum Post You are referring to the intake manifold and rockers I assume?He was... By oldcarmark ( 14 Years Ago )
Forum Post Hey, I found more interesting Y-block boats from net ;).... By Hollow Head ( 13 Years Ago )
Forum Post Boat?? Are you sure thats not a 56 Pontiac that made a wrong turn. By brokengate ( 13 Years Ago )
Forum Post Who really cares, as long as it has a Y-block inside of it :D... By Hollow Head ( 13 Years Ago )
Forum Post I have a 292 dearborn marine in my 54 f250,62-64 block ECZ-G... By F250RED ( 13 Years Ago )
