Fenton headers
Posted By Cactus 16 Years Ago
Posted 16 Years Ago
Have you acquired some Rams Horn manifolds, Ted?
Eddie Paskey
Posted 16 Years Ago
Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)Supercharged (294 reputation)
Posts: 294, Visits: 6.1K
Good Mornin' guys;;   Sure like my Sandersons,  work well, look well, and Fit well.  Their design (for tbird)  goes over the steering col, then down into exhaust pipe.  Used them with stock ex. manifolds--  also used them with Flaming River rack and pinion---   did not like the rack so changed to saginaw power steering box which is just right.  Sandersons fit thru all of these changes.  Just info-- maybe will help someone.   Thanks everyone for all the info that flows!!!   God Bless   Eddie
Eddie
Lake Forest, Ca. 92630
Posted 16 Years Ago
Ted (4/4/2009)
The 312 dyno mule I’m putting together is not far from being ready to do some testing and one of the first items on the agenda is some header testing.  If I had a set of Fenton’s here (on loan of course) when test time comes, those can be tested against the stock exhaust manifolds.  Besides a variety of tube headers to test, plans also include testing both the 1956 and 1957 manifolds just for a comparison between those two so a pair of Fentons added into the fray would be good.
   I can talk to him and see if he'll loan us a pair. Not sure if the test on one of your engines would equate to the results on a near stocker though.
Posted 16 Years Ago
charliemccraney (4/4/2009)
Don’t have a set of those.  If someone can loan a pair, I’ll include those in the testing.
pegleg (4/4/2009)
The header and exhaust testing will be performed on a 060 over 312 that’s going to be close to stock other than the camshaft and the intake manifold.  The heads are unposted G’s with minimal port work as this is the engine that is initially planned to be used for aluminum head testing.  Use of this engine for testing is by design as it mimics the modifications performed by many end users in their daily drivers.
Unibodyguy
Posted 16 Years Ago
Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)Supercharged (240 reputation)
Posts: 240, Visits: 848
Ted if you need a set of Ram Horns to test I can borrow you a old set that I have. Their not pretty but their in good shape.
        Michael
Michael
Sandy Valley, NV
Posted 16 Years Ago
I have a set you can use as well. The only functional problem with mine is that the holes at the exhaust pipe flange are pretty rough. One is stripped if I'm remembering right. I just used a nut and bolt to hold it together.
Posted 16 Years Ago
If someone is going to re cast new Fenton's, it might be worth their while, to try and improve the flow some. Given the small market, an improved product would be a lot more likely to sell..
Missouri Mike
Posted 16 Years Ago
Posts: 210, Visits: 1.2K
 These things sold for $872, can you beliueve it?????!!!???
 Missouri Mike
I'd rather be lucky than good.................
    but good ain't bad!!
Butch Lawson
Whistling Posted 16 Years Ago
Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)
Posts: 235, Visits: 20.9K
Aw shucks..........I was gonna bid
Butch Lawson
Manchester,  TN
Cactus
Posted 16 Years Ago
Posts: 229, Visits: 30.2K
I bid 400 dollars on these things thinking that was way too much and that I might get them for less than that.  Surprise, surpise.   Just think that for another 800 dollars this fool could have purchased the Paxton supercharger kit, and really had something.   There is one born every second.
Jan  Urbanczyk  Major USMC Ret.
        Bowie Maryland
