crane cams
Posted By 62galxe 16 Years Ago
Butch Lawson
Posted 16 Years Ago
Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)Supercharged (427 reputation)
Posts: 235, Visits: 20.9K
Thanks John.  The fellow I got the cam from said it had been in his shop for several years.  Looks like it will be a nasty sounding rascal in a small block ford.
Butch
Butch Lawson
Manchester,  TN
Butch Lawson
Posted 16 Years Ago
Almost forgot.  Did your catalog tell the firing order.  I would assume since it's for an early Ford (221-302) that it would use the 302 firing order.
Butch
Butch Lawson
Manchester,  TN
mctim64
Posted 16 Years Ago
Posts: 2.4K, Visits: 5.0K
Hoosier Hurricane (2/26/2009)
Butch:
My catalog says that cam fits 221-302 Ford.
Intake timing 54-88, exhaust timing 88-54, advertised duration 322, duration @.050-252, clearance .022 intake and .026 exhaust (obviously solid lifter cam), lift .526.  Centerline not given, but it looks to me like 107 degrees.  Ted?  Help here.  Street/strip cam with fair idle.
Fair idle? I doubt it. Tongue
Posted 16 Years Ago
John.  Doesn’t look like you need any help.  Your information matches mine and yes on the 107° lobe centerline.  But not sure how they came up with the ‘fair idle’ description and agree with Tim on the idle assessment as that particular cam also looks rather lumpy to me.  Rowdy is probably a better word.
Butch Lawson (2/26/2009)
Uses the early firing order or the same as the 289 and the FE engines.
Butch Lawson
Posted 16 Years Ago
Thanks everybody for your help.  I'm building a 302 for my grandson to get him started drag racing.  Looks like this would be a good cam to get him going.
Butch Lawson
Manchester,  TN
Posted 16 Years Ago
Last Active: 57 minutes ago
Posts: 3.7K, Visits: 323.2K
McTim:
I wondered about the "fair idle" also, but that's what the book says.  I wondered how a cam with 108 degrees overlap could idle "fair".  Butch, as I remember, cam grinders used to supply the same cams for 351s as 302s and you had to change to the 302 firing order.  This catalog had a separate column for 351s, but no part number.  You have the cam, might as well try it.  At least if it doesn't work, you'll have an idea which way to go from there.
Butch Lawson
Posted 16 Years Ago
The cam was basically free and that always makes it worth trying.  I don't want anything too radical or too fast for him until he gets enough seat time to handle it.  Looks like this will work to cut his teeth on.  Thanks again to all of you.
Butch Lawson
Manchester,  TN
