PUSHROD LENGTH
Posted By DANIEL TINDER 8 days ago
DANIEL TINDER
Posted 5 days ago
Posts: 1.8K, Visits: 154.7K
cos (11/18/2026)
Thanks Kutulz    I was surprised to see that e E and F code engines used shorter Push rods. Must be because the EDB  (F) code cam  had more lift. But  doesn't make  sense  with E-code engines. I have read the 285 HP E-Ecodes  engiines used the EDB blower cam. Wondering if it is really true.   F and E code  experts ever heard of this?
I’m curious also.  Maybe the shorter rods (used with high-lift cams) were a deterrent re: ‘piston-valve’ interference at very high RPMs (?)
6 VOLTS/POS. GRD. NW INDIANA
Posted 5 days ago
DANIEL TINDER (11/19/2026)
cos (11/18/2026)
Ted Eaton told me that piston-to-valve clearance shouldn't be a problem if your net valve lift is less than .535, and you have flat-top pistons.
Having oversize valves and a cam with a lot of overlap can be a problem as well. Sometimes it's necessary to notch the bores above the rings for additional clearance. Ford did the same on the Boss 302 engine with large-valve Cleveland heads.
Posted 2 days ago
Posts: 7.6K, Visits: 206.1K
Here’s my two cents worth on the pushrod subject.
The rocker arm oil baffles (aka valve spring shields) are completely absent in my 1959 parts catalog, but I did find them in some earlier Ford and Mercury catalogs under the basic part number 6524.  Based on the information provided in the earlier catalogs, it’s not clear as to when those valve spring baffles were discontinued.  All the 1954 & 1955 engines would appear to have them but after that, references are vague.  Knowing exactly when they ceased to be a production item would possibly help to explain some of the pushrod length variances that were occurring during those early years.  The problem with most of those part catalogs was that they were compiled and printed prior to the start of a production model year and subsequently did not show any parts changes that occurred during the model year.  Changes were often issued in a TSB (technical service bulletin) or a supplement to the catalog.
Putting that to the side, I always felt the move from the 8.297” pushrod (‘54 & ‘55) to the 8.188” pushrod in 1956 and 1957 was due to the switch from the 1.43 rockers to the 1.54 rockers.  Intuitively, a longer pushrod would have been required for a higher lift camshaft from the perspective that the camshaft base circle was reduced which would have made the tappet resting in a lower position.  Assuming that the increase in rocker arm ratio coincided with the removal of the valve spring oil shields, that would have been a quick production fix for maintaining a respectable rocker arm geometry.  That would have prevented the need for a different rocker arm pedestal (stand) and/or a redesign of the heads to alter the rocker arm shaft height.
Best guess on my end is that the 8.158” pushrods were for the 0.290” lobe lift camshaft that was available for the 285HP dual quad engine and the first run of supercharged engines.  A TSB may have given some detail on this but I have not seen one that covered pushrods in particular.
It’s interesting that Ford went back to using both the smaller lift camshafts and 1.43:1 rockers in 1958 but did not go back to using the valve spring shields.  Removing those shields may have simply been a cost cutting measure to begin with and actually having nothing to do with valve lifts, pushrods lengths, and/or valve train geometry.
DANIEL TINDER
Posted 2 days ago
I find it very strange that the published catalog spec. for pushrod length was listed in fractions for the earlier/longer model, but in decimals for all others.
So, if the variation in pushrod lengths were due only to cam lift, rocker ratio, etc., then it can be assumed that all Y-Block heads, regardless of production year, had the same exterior dimensions (?).
Posted 2 days ago
Posts: 2.0K, Visits: 306.7K
I just won't learn ... http://forums.y-blocksforever.com/uploads/images/f305702f-699d-4a43-ac9f-6d94.gif
What you see in the FORD MPC is SERVICE PARTS for a simple stock service/rebuild.
If one is modifying an engine, one must arrive at CORRECT VALVE-TRAIN GEOMETRY including correct ROCKER ARM SWEEP.
TED's articles detail exactly how to go about it, especially if aftermarket rocker arms, spring tension/bind, etc.
You need (IMO) two quality checking push-rods and measure each cylinder or you can make a gamble.
The cam has to be de-greed and events checked against the cam card. You want no valve to piston contact, especially after the engine warms and you wind it to 6000 plus.
In your rebuttal, try and leave out references to female body parts as I am old with a weak heart and the old lady has been frigid since 9/11.
DANIEL TINDER
Posted 2 days ago
KULTULZ (11/23/2026)[hr
Custom pushrods are likely expensive, and the ‘off the shelf’ chrome moly Y-Block rods apparently only come in stock lengths.
A plant-based diet would help that weak heart, and maybe put lead back in your pencil 😁
Posted 2 days ago
"A plant-based diet would help that weak heart, and maybe put lead back in your pencil 😁"
Well, I was on a barley and malt liquid diet regimen for years and lost no weight ...
As for LEAD IN THE PENCIL, I have no one to write to ...
My 'LITTLE THUMB-SCREW' suddenly realized where rug rats come from and after our 2nd child, and declared she was giving up sex for thirty days (LENT) and never repented  ...
But hopefully you know where I was coming from (watch your six) ...
