Rocker Arms
Posted By BamaBob 2 Weeks Ago
BamaBob
Question Posted 2 Weeks Ago
Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)Supercharged (434 reputation)
Last Active: 6 hours ago
Posts: 160, Visits: 12.0K
I have some questions about ECG 6564 rocker arms. I have read on this forum from several years ago that all ECG rockers are 1.54 ratio. Is this correct? Also, I read that the ECG 6564- A2 arms are supposed to be equipped with the two piece adjuster screw and locknut, while the ECG 6564-B2 is supposed to have the interference one piece type adjuster screw. Is this correct? If so, will the two types interchange, that is, can the two piece adjusters be used  on the B2 rockers and vice versa? Are the adjusters the only difference in the two different numbered arms? Would it hurt anything for the A2 and B2 rockers to be mixed on the same shaft?
I am planning to have several sets of both 1.43 and 1.54 ratio reconditioned rocker arm assemblies up for sale within the next few weeks and I want to make sure I will be selling the absolutely correct items. At present, I am planning to have the two-piece adjusters on the 1.54 rockers, and the one-piece interference type adjusters on the 1.43 rockers. I know there are some very knowledgeable people with a lot of experience on this forum and I look forward to hearing from you!
Posted Last Week
Posts: 2.0K, Visits: 306.7K
There has been much discussion here on this subject on various threads.
I have no luck with the SEARCH FEATURE here but this information is here somewhere.
DANIEL TINDER
Posted 11 days ago
Last Active: 7 hours ago
Posts: 1.8K, Visits: 154.7K
I’m curious also.  My aftermarket interference/hexhead adjusters also came with locknuts, that spin easily like those with the orig. slotted adjuster pairings. If my repro locknut threads are identical to the originals, that would mean my aftermarket repro rocker threads must be different from the orig. FoMoCo rockers, assuming the interference adjusters interchange with Ford parts (?). Very confusing issue. It WOULD be nice to get this all finally sorted out.
 If you plan to successfully use both type adjusters on both ratio rockers, that would have to mean the rocker threads were all the same throughout Y-Block production, and the hexhead/interference adjuster threads were different from the slotted type.
6 VOLTS/POS. GRD. NW INDIANA
Posted Last Week
When most of this was being discussed here in the past, I kept post excerpts/notes and have been too lazy to sort them out since.
If no one else replies, I will try and sort/post. The valve-train saw a big engineering change in the 1956 production run.
Which style rocker arm are you describing?
http://forums.y-blocksforever.com/uploads/images/b90a3a7b-bd0a-4bd7-a355-187c.jpg
http://forums.y-blocksforever.com/uploads/images/f957783b-7186-4ce4-af56-a8c6.jpg
http://forums.y-blocksforever.com/uploads/images/f7b92952-c10b-42d1-8161-e20c.png
Posted Last Week
Posts: 7.6K, Visits: 206.1K
It’s been a while since swapping out parts on the factory rockers, but I was thinking that the A2 rockers were spot faced at the top of the threads so that the adjuster nuts would tighten down more squarely.  The interference adjuster screws did not require that particular feature on the B2 rockers.  Correct me if I'm wrong on that or there's some different information regarding that.  Threads were the same for each style of rocker though which makes the adjuster screws working within each.
See if this link to a past thread helps.
http://forums.y-blocksforever.com/Topic152486.aspx
Posted 10 days ago
Posts: 3.7K, Visits: 498.3K
There was an article on rocker arms in YBlock magazine (I have the article but not the month/year it was issued). One difference in the rockers was the part that the adjuster went in - in the lock nut version the rocker was thicker than the interference style.  When I assembled the heads on my 312 I was missing either the threaded part or the nuts on two of the rockers so I used an interference fit.  It worked ok, but due to the extra thickness of the rocker I was almost out of adjustment room when I adjusted the valves.
Posted Last Week
- INSTALLATION OF SELF-LOCKING TAPPET ADJUSTING SCREWS IN EARLIER ENGINES (1954-56) -
1954-56 MODELS - (EXC. CARS WITH HYDRAULIC LIFTERS)
When installing self-locking screws to replace earlier type (with lock-nut), all parts listed below must be installed as a unit:
1956 Engines - Self-locking Tappet Adjusting Screws
Part No. B6A-6549-C AND Valve Rocker Arms Part No. B6A-6564-C.
1954-55 Engines - Self-locking Tappet Adjusting Screws
Part No. B6A-6549-C must be used with NEW Valve Rocker Arms Part No. B6A-6564-D and NEW Valve
Push Rods Part No. B6A-6565B
EAN Rocker is 1954-1955 1.43:1 ratio
5751066 is 1958 - 1964 1.43:1 ratio
C0AZ 6564-A is the SERVICE REPLACEMENT PN for 5751066
1.54:1 HIGH RATIO ROCKERS ARE ECG 6564 PART#
ROCKER ARM RATIO  VALVE DIAMETER  PUSH ROD LENGTH (Effective)
EAN  54-55 jamb nut 1.43:1  EXHAUST all 1.51" 1954-55 3/16" radius ball 8.11"
ECG 6564  56 jamb nut  1.54:1 INTAKE 1954 1.64"  1956-59 3/16" radius ball 7.98"
ECG 6564  57 self-locking 1.54:1 INTAKE 1955-56 1.78"  1960-64 3/16" radius ball 8.11"
5751066 58-64 self-locking 1.43:1 INTAKE 1957-59 1.93"
MUMMERT
________________________________________________________________________________
If converting the friction style of rocker arms adjustment screws over to the earlier stud and jam nut combination, then a 7/16 X 20 tap needs to be run through the rocker arm threaded holes to restore the thread finish to one that’s suitable for the earlier stud style – TED EATON
