CYLINDER LUBE (?)
Posted By DANIEL TINDER 2 Weeks Ago
DANIEL TINDER
Posted 6 days ago
Posts: 1.8K, Visits: 154.7K
KULTULZ (11/18/2026)
The OEM push-rods are subject to bending.
Tubular will hopefully prevent that. It is just insurance.
These will give you an idea of how to achieve correct valve-train geometry
https://www.enginebuildermag.com/2009/08/how-to-verify-proper-valve-train-geometry/
https://www.measuringknowhow.com/expert-guide-how-to-measure-push-rod-length-correctly/
TED will advise as to source/quality and over-ride above info if necessary.
Those links are useless, since they don’t apply to the Y-Block’s shaft style rocker assemblies (ok for scrub & SBF owners though).
6 VOLTS/POS. GRD. NW INDIANA
Posted Last Week
Posts: 2.0K, Visits: 306.7K
"Those links are useless, since they don’t apply to the Y-Block’s shaft style rocker assemblies (ok for scrub & SBF owners though)."
Those links are an intro of how to go about achieving proper VALVETRAIN GEOMETRY. That is the info what you wanted, correct?
It can get much more complicated according to engine style.
An engine is an engine regardless of foundry marks and they all work basically the same.
DANIEL TINDER
Posted 5 days ago
🤪 That’s like saying ‘all women are basically the same, since they all have breasts & a vagina’.
True, the object & measurement concept for determining proper valve train geometry are rather similar with pedestal-style mechanisms, but the procedure to accomplish is completely different with Y-Blocks.  Novices might become much confused & misdirected by those links.
If I knew how to post them, Ted’s excellent Y-Block mag. articles available on his website would be the best choice for proper instruction on the subject.
BTW: I remember now, that I had purchased the longer pushrods (even though the parts book designated the shorter ones for late 50s heads), since running with the adjusters farther up maximized effective rocker ratio/valve lift.
Posted 5 days ago
SORRY TO HAVE UPSET YOU DANIEL ...
Posted 2 days ago
Posts: 7.6K, Visits: 206.1K
DANIEL TINDER (11/19/2026)
...If I knew how to post them, Ted’s excellent Y-Block mag. articles available on his website would be the best choice for proper instruction on the subject.
Here’s the link to the rocker arm geometry article that was previously published in The Y-Block Magazine.
Rocker Arm Geometry – Eaton Balancing
DANIEL TINDER
Posted 2 days ago
FYI: Those interested should also view (inclosed in Ted’s link) the added article re: ‘Varying rocker ratio/pushrod length’.
