DANIEL TINDER
Posts: 1.8K,
Visits: 154.7K
So, just wondering if I should maybe squirt a dap of oil into the cylinders of this rebuilt motor (that has been sitting inside for 16+ yrs.), and turn it over by hand a few times before I install/bolt down the rockers and set the lash. Would that make it any easier to start the first time, or could the oil possibly inhibit initial combustion by diluting/contaminating the mixture? The cylinders were open to the (conditioned) air all that time (no sp. plugs, plastic bag but not airtight), but the crank was at least turned occasionally.
6 VOLTS/POS. GRD. NW INDIANA
Visits: 206.1K
Nothing wrong with a shot of oil in each of the cylinders and turning the engine over to prelube those cylinders. Having the rocker arm assemblies off of the engine while doing this would prevent any excessive wear that could take place on the camshaft and tappets as the lube has undoubtedly drained from those during the down time. Sitting that long could also have the rings sticking so the oil in the cylinders would help in that regard. Taking this to the next level would be to pressurize each cylinder to force the oil around the piston rings. ATF works good for the lube in this instance. Pulling the distributor and prelubing the engine with any kind of driver on the oil pump shaft wouldn’t hurt either but do that with the rocker arms in place so you can ensure that the rockers are also getting oil. If the rockers are off while prelubing the engine, then be sure to put some kind of shield over the rocker arm oil passages in each head to prevent a massive flow of oil going where it does not need to go. That’s the best-case scenario as worst case would be no oil at all coming from the heads.
DANIEL TINDER
Posts: 1.8K,
Visits: 154.7K
Thanks Ted, I’ll pick up a quart of ATF, though I would likely have loaded the squirt can with some ‘Marvel Mystery Oil’ I have on hand. As far as “pressurizing the cylinders”, I’ll have to just force the pointed blast attachment of my tire inflator pump into the sp. plug hole, and rig a rubber seal of some sort (I assume the engine would be too hard to turn if the sp. plugs were installed before the rockers could open the valves?).
I already have a spare distributor shaft and H.D. power drill to prelube the fully assembled motor before first start, as that entire routine has previously been much studied (full fuel pressure, 20+ degrees of initial timing, etc., etc.). In fact, an extra long prelube period would likely be helpful in my case, as circulating the oil repeatedly would keep the valley flooded longer, in order to saturate the dry tappets & cam.
DANIEL TINDER
Posts: 1.8K,
Visits: 154.7K
DANIEL TINDER (11/13/2026) As far as “pressurizing the cylinders”, I’ll have to just force the pointed blast attachment of my tire inflator pump into the sp. plug hole, and rig a rubber seal of some sort
Turns out, a very cheap Schrader valve/18mm plug thread adapter is available online. I’ll just flood each cylinder with ATF, open the oil pan drain, and let the inflator run. Turning the motor over by hand afterwards will likely be a bit messy, since the rocker shaft gear is still not bolted down yet, so I’ll probably tape some absorbent gauze over the plug holes. BTW: While transferring the used rocker assemblies from the old engine, I noticed some of the pressed-in tubular pushrod cup stems had come loose. Don’t know how that might effect valve timing, since the pushrods will still be captured once the shafts are bolted down, but just to be safe I’ll super-glue them nonetheless, so the cup stems can’t stick or bind extended, thus closing the lash.
Posts: 2.0K,
Visits: 306.7K
" BTW: While transferring the used rocker assemblies from the old engine, I noticed some of the pressed-in tubular pushrod cup stems had come loose. Don’t know how that might effect valve timing, since the pushrods will still be captured once the shafts are bolted down, but just to be safe I’ll super-glue them nonetheless, so the cup stems can’t stick or bind extended, thus closing the lash."  I think it might be wise at this point to invest in a nice set of quality tubular push-rods. TED will know the current good ones.
Posts: 2.0K,
Visits: 306.7K
Is the engine on a stand? If so, position one bank as to point up and introduce the ATF and let the oil sit for a few days to allow it to seep into the rings. Turn the engine a few days later and repeat on opposite bank. Pressurize the oiling system before turning the crank (bearing protection). Turn after pressurizing (again slow and gingerly) Turn the crank enough in a series to allow one (each) piston at a time reach full bottom depth and hit each cyl with more ATF while it is bottomed. Repeat on each cyl. rotating very slowly/gingerly. This should allow the cyl walls to receive some protection before firing. Confirm the tappets are turning freely while turning by hand. Use only a QUALITY BREAK-IN OIL and FILTER for run-in. Drop the oil after run-in and replace with QUALITY STREET OIL and QUALITY FILTER (no WALLY-WORLD LOW BUCK SPECIALS). Were you there when the engine was assembled and lubed for storage? - ALL OF THE ABOVE MUST BE APPROVED BY THE ON-SITE QUALITY CONTROL AGENT -
DANIEL TINDER
Posts: 1.8K,
Visits: 154.7K
Stand doesn’t rotate, and the valley is already sealed. I hadn’t planned to fill the crankcase until the motor was installed, but I suppose it wouldn’t hurt. Engine came from John Mummert. It’s. just a case of figuring out the correct procedure order, as I likely can’t pressurize the bearings until all the ATF is drained. The USA pushrods were working fine until the head gasket went, are all the correct length & broken-in/matched to the specific rockers, and show no suspicious wear patterns. It would be just my luck to end up with poorly manufactured replacements that fail. Unless expert advice convinces me the loose stem/superglue fix is a serious issue (?).
Posts: 2.0K,
Visits: 306.7K
" Stand doesn’t rotate, and the valley is already sealed. I hadn’t planned to fill the crankcase until the motor was installed, but I suppose it wouldn’t hurt. Engine came from John Mummert." ...whoa ... Forget what I posted. The assembly quality is in no question. Just follow TED's advice then.
Think about quality tubular push-rods, though. Cover-your-butt.
DANIEL TINDER
Posts: 1.8K,
Visits: 154.7K
KULTULZ (11/16/2026)
Actually, you’ve got me thinking: These pushrods are OEM/250# spec., not ‘race’ quality. Plus, I’ll have to measure them, as I can’t remember if I specified the correct length when I originally ordered them (‘55 block but 113 heads), & seller’s invoice doesn’t specify. The higher lift cam, police grade springs, etc. might warrant a better grade, and the block decking/head milling might alter optimal length. After the shafts are bolted down & the lash is set, I’ll check the adjuster position and maybe give Ted or John a call.
Posts: 2.0K,
Visits: 306.7K
