Tunnel Cram
Posted By Litshoot Last Month
Posted Last Month
Posts: 7.6K, Visits: 206.1K
KULTULZ (10/23/2026)
Is there a photo of the engine rear available? I'd like to see how that coolant crossover (?) is plumbed.
http://forums.y-blocksforever.com/uploads/images/274ffd1c-c267-4da8-847d-acd2.jpg
No picture readily available but the radiator on the dragster was behind the engine which required the coolant lines exiting the intake manifold adapters to be routed to the rear of the engine.  You can see the junction and coolant fill point in the picture at the rear of the engine where the two lines join up and the water is actually added.  From there, an electric water pump circulates the coolant.
Posted Last Month
Posts: 2.0K, Visits: 306.7K
THANX! for the reply TED.
TECH obviously above my pay grade ...
