Edelbrock carb linkage ?
Posted By RossL 3 Months Ago
RossL
Posted 2 Months Ago
Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)
Last Active: 7 days ago
Posts: 168, Visits: 7.3K
Installed manifold and new carb this week.
I used 3/16" spacers under the 55 bell crank.  These were needed to clear the "B" manifold
http://forums.y-blocksforever.com/uploads/images/a01cebf6-b717-4286-bd5e-b033.jpg
 I fabricated a link (copied from Joe Johnson)  to eliminate the spring linkage, I now can confirm the spring linkage is needed to engage the kick down.
http://forums.y-blocksforever.com/uploads/images/cce2a610-5c7f-4d49-9d62-d197.jpg
Because the Edelbrck is a wider carb I had to build out the rear fastener to use the Spring
http://forums.y-blocksforever.com/uploads/images/88ac0b13-3ef3-47c2-a635-cd21.jpg
For now I am using a Ford look alive 2" drop base air cleaner with a 1/4" spacer.  I have about an inch of extra clearance, I might use a 1/2" spacer OR maybe I will source a 57 air cleaner..................
Right now I am in the process of dialing in the carb.  Ni I am not driving around with Play Dough under the hood LOL
http://forums.y-blocksforever.com/uploads/images/8db362c6-32e1-41ab-a9df-ce32.jpg
FORD DEARBORN
Posted 2 Months Ago
Posts: 852, Visits: 113.5K
Very nice work looks great. IMO, that aircleaner assembly looks natural....
Posted 2 Months Ago
Last Active: 39 minutes ago
Posts: 2.0K, Visits: 306.7K
- BEAUTIFUL WORKMANSHIP !!! -
" I fabricated a link (copied from Joe Johnson)  to eliminate the spring linkage, I now can confirm the spring linkage is needed to engage the kick down."
The 57 BIRD also uses a solid throttle linkage rod.
Wondering, were you able to get the TV adjustment correct with the 57 intake and 56 bell-crank?
That would be my worry.
I fell down on my promise to find the reason for that throttle linkage. I will still look and post the reason here at some point.
RossL
Posted 2 Months Ago
KULTULZ (9/11/2026)
Talking with someone that knows the 55,56, 57 Tbirds...................the 57 uses a solid link, because the "spring action" is built into the bell crank.  So it (57 bell crank) uses the same"concept" but it's not really obvious.   When I used the solid link with the 55 bell crank there was not enough movement/leverage to engage the trans kick down.  That additional spring action keeps pushing the linkage when the carb is fully opened.  I can only guess they designed it this way to allow for wide open throttle without the downshift, giving you the option to stop applying pressure unless you need the acceleration/down shift.
After learning this I had to remove and "retire" the solid link that took me hours to fabricate...............  When I installed the spring/link with the 55 bell crank my trans is now down shifting as expected
RossL
Posted 2 Months Ago
FORD DEARBORN (9/11/2026)
Air cleaner was $70 on ebay with a washable filter element.   I didn't want to cut up a $500 repro 57 air cleaner that might not fit under the hood even if modded
Posted 2 Months Ago
"After learning this I had to remove and "retire" the solid link that took me hours to fabricate...............
When I installed the spring/link with the 55 bell crank my trans is now down shifting as expected."
I really appreciate your coming back to explain that. I had no idea.
RossL
Posted 2 Weeks Ago
I felt the dropbase air cleaner was trapping and holding too much heat since it shrouds the top 1/3 of the carb.  I tried a 1/2" spacer and a "borrowed" 57 air cleaner but I think it's too close to the hood for comfort.  I found this air cleaner on Amazon.  The air cleaner  (sits about 1.5" taller than the drop base) 12" oval sits inside the hood scoop and I still have at least 1/4" clearance.   It sort of matches the theme of the valve covers.  My car is NOT concours spec but I wanted something that "fit visually".  I will have to wait for a hot day to see if it helps keep the carb coolerhttp://forums.y-blocksforever.com/uploads/images/ba1ac63b-dd6e-40d3-94a9-343d.jpghttp://forums.y-blocksforever.com/uploads/images/6e0c85bf-6217-4687-9b78-47f0.jpg
Posted 2 Weeks Ago
I think it looks great as to where you don't desire originality.
Does the smaller ACL hide within the hood scoop (extra clearance)?
And you are correct in a broad base/ and/or drop base ACL retaining engine heat not just around the carb body and also affects intake air temp. The BIRD has a high under-hood air temp to begin with.
Below photo shows how to measure ACL to HOOD clearance with modeling clay -
http://forums.y-blocksforever.com/uploads/images/38dcd37c-a63b-4a6e-a008-7ea4.png
http://forums.y-blocksforever.com/uploads/images/fb537e27-fcb9-4cdb-b76a-49f0.jpg
Posted 2 Weeks Ago
I FORGOT -
NICE DETAIL WORK!
