Advance Cam Timing or Leave it as Stock?
Posted By oldcarmark 3 Months Ago
Posted 3 Months Ago
Posts: 3.8K, Visits: 33.2K
http://forums.y-blocksforever.com/uploads/images/df44e93c-fc9a-47ba-9509-c4c5.jpghttp://forums.y-blocksforever.com/uploads/images/92c83ee4-1aca-478e-86fa-8993.jpgI am having trouble figuring out  how to use the muti  Keyway Crank Gear. I can see how it goes if stock original Timing is wanted. One Mark on Keyway and One on outer Edge of Gear. If I want to advance Timing I think by just 4 Degrees what are the reference Points I need? The Picture from Y-Block Book I am thinking shows the Keyway to use and the Tooth marked A4 is what. The Timing Mark to count Pins? Thanks.
Posted 3 Months Ago
Posts: 2.0K, Visits: 306.6K
Who is the vendor (seller) of the timing kit?
Can you give PN?
See if this helps - https://www.eatonbalancing.com/2015/09/24/degreeing-in-the-camshaft-part-iii-its-twelve-pins-between-the-marks-for-the-ford-y/
Posted 3 Months Ago
I figured it out. For now I am leaving it in original Timing setup. I don't have Information on the Camshaft Timing Specs so for now I want to get it finished and running without wondering if I have set timing correctly. I can always revisit Timing if I want to try Interesting the Comments from couple of other Members regarding their Experience with advancing Timing.
