Visits: 206.1K
KULTULZ (8/26/2025) TED, If you ever find the time (yeah, right), could you keep the board informed on whatever modifications you perform or come across regarding the MEL? There are many LM and J-BIRD enthusiasts out there. THANX!Will do. The M-E-L and 385 series (429/460) share the same camshaft to crankshaft centerline so that’s where I will be starting from. Right now I am looking at the Milodon ‘cheater’ gear drive set for a 385 series to determine if that setup can be adapted to the M-E-L engines.
