Noisy rockers
Posted By idaho211 Last Year
idaho211
Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)
Posts: 128, Visits: 11.6K
Rocker arms unlimited. Did run into a problem initially. The adjuster screws were defective. Kept backing off so changed to NOS jam nuts which did fix the problem.
Posts: 1.8K, Visits: 306.4K
JUST FYI
O/S ADJUSTERS are available. I would prefer the locking nut style on a HP engine myself personally.
http://yblockguy.com/techtips/rocker_arm_assy.htm
BamaBob
Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)
Posts: 157, Visits: 11.8K
Kultulz, Where are new rocker arm adjusters available from? I have been looking for new ones without any success. Either style would be OK, however I would prefer the lock nut style if I could get them. Thanks for any information!
Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)Supercharged (3.2K reputation)
Posts: 1.3K, Visits: 1.9K
John Mummert, ford-y-block.com. He doesn't have online ordering; you'll have to call. The best time to call is between 3:45 and 5, PST.
DANIEL TINDER
Posts: 1.7K, Visits: 154.3K
I have friction screws AND locknuts (belt & suspenders). Also, the hex screws are then easier to adjust more precisely when using a P&G gapper tool (unless you have 3 hands 😁).
6 VOLTS/POS. GRD. NW INDIANA
See if this link works - https://www.youtube.com/watch?v=Q7ZjObWyRJU
It shows a correct rebuild.
Also - https://www.youtube.com/watch?v=mRaiMciNbDA
THIS - https://www.youtube.com/watch?v=Pst0mEdD018&themeRefresh=1
... will help explain the system.
https://www.youtube.com/@mummertsspecialvinterests2721/playlists
DANIEL TINDER
KULTULZ (7/17/2025)
Interesting.  Didn’t like what he said about the “import imposter/bad metallurgy” aftermarket adjusters (same style as I bought on eBay 20 yrs. ago).  Guess I should check for excessive ball wear, even though they still hold adjusted clearance well.  Too bad he didn’t elaborate re: history.
Did anyone find out if JOHN MUMMERT offers the O/S adj. screws?
C2AZ 6549-A - .0023 O/S
Several years ago, FORD TRACTOR was offering them.
