1955 Thunderbird Fuel problem
Posted By RossL 8 Months Ago
FORD DEARBORN
Posted 8 Months Ago
Last Active: 4 days ago
Posts: 789, Visits: 113.4K
Many years ago while trying to solve very similar problems on a Jeep, I discovered the small screen filter built into the inlet connection of the carburetor had a lot of heavy rust debris where that screen filter resided. When fuel was flowing, the particles would one by one begin to accumulate on the screen, eventually blocking it. Engine would quit, then within a few minutes after the particles separated from the screen, the engine could be restarted and the process repeats. You did state you tried another carb but not sure when that happened. Good luck....
RossL
Posted 8 Months Ago
Supercharged (210 reputation)Supercharged (210 reputation)Supercharged (210 reputation)Supercharged (210 reputation)Supercharged (210 reputation)Supercharged (210 reputation)Supercharged (210 reputation)Supercharged (210 reputation)Supercharged (210 reputation)
Posts: 79, Visits: 7.1K
FORD DEARBORN (4/23/2025)
I didn't test the second carb yet.  Hopefully tomorrow.  Earlier in the week I checked the screen in the carb inlet and it was clear (replaced last year)
RossL
Posted 8 Months Ago
$8 cure for vapor lock$8 Cure for vapor lock
Daniel Jessup (4/18/2025)
Do you run fuel that has ethanol in it? If so, check out this article I wrote - it has video as well showing the bubbling because of the low boiling point of ethanol.
https://www.hotrodreverend.com/post/2019/07/13/1955-ford-part-81-running-with-the-devil
At times, gas stations have way more than 10% ethanol in their "gasoline" and that only makes matters worse. Get a tank of that and it's really a problem. Ted Eaton has more on this concerning fuel that has ethanol and his personal testing of the percentages. Typically, the high octane version at the pump will have the least amount of ethanol.
I think the problem is due to heat as you indicated.   I drove this car in above 90 degree weather last year with the AC on for an hour or two no issues whatsoever.  I'm not ready to start making changes until I test everything else.
I did this on a Corvette a few years back and I might try it again.
RossL
Posted 7 Months Ago
After weeks of trouble shooting with no solution,  I replaced the heat riser with a blank spacer.   I don't believe the heat riser was opening 100%.   This seemed to make things a little better.............. the car was still stalling out.  I previously installed an electric pump which helped, the car would not stall out as easy, but it would still not idle correctly.
I ran out of things to look at in the fuel system, I pulled the plugs and #8 had this black stain.   I installed a new exhaust gasket on the drivers side and the problem went away.
This exhaust leak must have been raising the under hood temps enough to boil the fuel and shut down the pump.
I've driven the car 5 hours and it seems to be OK.   Previously it would stall out after 40 minutes of driving.   I still need to see how it will handle stop and go traffic..............
http://forums.y-blocksforever.com/uploads/images/f7549da4-576c-4299-8c66-0d6c.jpg
