Last Active: 4 Months Ago
Visits: 23.8K
That's a pretty good deal if you're anywhere near LA.
Posts: 1.4K,
Visits: 2.0K
The seller claims that the block was fully machined and bored +.030 over 10 years ago. Up until two weeks ago, it had been wrapped in plastic and placed in storage. The pistons are new/w rings installed. The block appears to have new brass freeze plugs and cam bearings installed. Cross-hatched cylinders can be clearly seen in the photos. Although it would be cost-prohibitive to ship the block, the pistons and rings would be a good deal for someone needing +.030 cast pistons for a stock rebuild. The cost to ship the pistons by UPS Flat Rate should be about $20.
losangeles.craigslist.org/wst/pts/d/los-angeles-ford-292-block/7717804585.html
