Visits: 33.0K
Thanks for the input, Ted. Yes, 2 compression tests have been done, one by me and the other by my mechanic. Both tests were within a couple of pounds of each other with 7 cylinders at 120 and #2 at 110. #2 is really hard to check due to obstructions of the generator and battery tray and the heater blower. Possibly it would test higher if I could get my old hands down there easier. Valves were adjusted about 1,500 miles ago.
As stated above, the crank gear mark is at 3 o'clock (TDC compression stroke) but the cam gear mark is at 9 o'clock. What is the solution to get both gear markings to be aligned at 3 o'clock so I can check the number of chain link pins between the two marks. Also, as stated above, I am unable to find any marking on the chain to align with the gear marks.
Last Active: 5 hours ago
Visits: 112.6K
There is no markings on the chain ~ to get the crank and cam marks to their 3 o'clock (and a bit) position, you will have to remove the cam gear. Then get the crank and cam gears in position with 12 links between marks. Also, watch this video ~ https://www.youtube.com/watch?v=b1Z2L9pgMXU I'm sure it will help..
Last Active: 19 minutes ago
Posts: 7.5K,
Visits: 205.8K
Lanny White (7/13/2022) As stated above, the crank gear mark is at 3 o'clock (TDC compression stroke) but the cam gear mark is at 9 o'clock. What is the solution to get both gear markings to be aligned at 3 o'clock so I can check the number of chain link pins between the two marks. Also, as stated above, I am unable to find any marking on the chain to align with the gear marks.To get both gears so that the marks are at the three o’clock position, you just need to rotate the engine another complete revolution.
The timing marks are in position when the #6 cylinder is at TDC and on its compression stroke. The #1 cylinder would be at TDC but the valves would be at their overlap cycle. Most timing chains made now for the Y do not have the off-colored links to facilitate locating the chain on the marks. You simply need to count the pins between the marks and ensure that it is twelve pins between the marks. Be sure that you count 'pins' and not 'links'.
Visits: 33.0K
Well, here I am again. Ugh!! Tore the timing cover off, removed the chain and gears, no problems found upon inspection, reinstalled using the proper alignment as previously described, started the engine, no change.
Bought a new (made in USA) timing chain and gears, removed the old and installed the new using the proper alignment, started the engine, ran fine for a few minutes. Shut it off to make minor adjustments, started it again and it began misfiring out the exhaust just like before.
Pulled the newly rebuilt carb apart for another inspection, blew out the passages, reassembled and installed, put in a new USA rotor just for grins. Started the engine and it ran fine for about 10 minutes. Thought we had it, finally! Shut it off for minor adjustments and restarted. Misfiring as before. Same as it has been for over a year.
Distributor is a rebuilt, engine was running perfectly before this mess started a year ago. I have no way to check the dizzy to see if the problem is with it. I have had it out many times and inspected it until I am blue in the face. Any suggestions on a dizzy guru with some old-time fancy equipment that can give me an Rx to see if its dead and then make it well? Any suggestions on where to locate a 1954 rebuilt dizzy? I'm pulling my hair out!!!!
Visits: 285.6K
I know how frustrating those problems can be as I just got through a similar one myself. I suspect you have an ignition problem as it sounds like you have checked everything else. Are you running points and a condenser? If so, there are a bunch of junk Chinese parts out there. Go to a NAPA store and buy good quality parts and try again. Change the points, condenser, rotor and cap. Make sure all the internal wires are good and tight. What coil are you running? You can check your coil with a multi meter. Are your ignition wires good? Especially check the coil wire as it can cause all kinds of intermittent problems. You will not be able to time the engine with a timing light until you verify your timing mark, but you can get it close by hand. Keep looking and you will find the problem.
Visits: 335.2K
You mention in a previous post about a vacuum reading fluctuating and in another post you were going to look for leaks but I find no results of that. Did you and also what was your vacuum reading at idle and when you try to rev up ? Reading the vacuum gauge can tell you where to look:
1936 Ford 3W Coupe : 56 T-Bird 312, 47 Packard 3 speed, 40 juice brakes. 1968 Merc Cyclone FB GT 390, Getting a better front clip! 1977 Ford F-250 Supercab RWD Explorer Long box. 1976 Chev Camaro RS LT Future rebuild : 1949 Ford F-1
Visits: 33.0K
This has been quite a rodeo. Thank you all for your help.
It appears that the culprit was a distributor shaft that is slightly undersized in diameter causing the rotor to not seat firmly. Yes, the spring clip was/is in place. I tried several new rotors, some of which were NOS, and all were slightly sloppy on the shaft with movement left and right and rocking up and down. I hadn't noticed the rocking until last week. A friend gave me a 1954 dizzy that is in good shape and all of the rotors fit snugly on it. A quick clean-up, points, and condenser and she fired right up. No more cackling!
I believe that when the engine was cold the rotor had been a little more snug but as it warmed then it started flopping around a bit more, thus running quite well for a few minutes and then beginning the crazy misfiring.
Got it running on Friday, fifty mile round trip to a car show on Saturday. I will run some Seafoam thru it, reset the low speed mixture and timing with the vacuum gauge, and I think I am good to go!
