Stuck distributor
Posted By B-rad 3 Years Ago
FORD DEARBORN
Posted 3 Years Ago
Posts: 789, Visits: 113.4K
I have in two separate occasions installed distributors from a Lincoln Y-block in a Ford Y-block by changing the distributor gear to a Ford Y-block gear. These were Lincoln Y distributors of 57 and later vintage. Therefore, there is no reason the swap wouldn't work the other way.  Assuming all Lincoln Y blocks are machined the same, a dual advance Ford Y distributor would fit your 54 Lincoln Y by reusing your original gear properly placed on a Ford Y distributor. Assuming the early Lincoln Y blocks are machined the same as 57 and later blocks.
Posted 3 Years Ago
Posts: 1.9K, Visits: 194.9K
Assuming the distributor interchanges with the gear changed, and assuming the 54 is the Holley 4000 (a lot of assumptions) here’s a link to Ted’s article on modifying the Holley.
https://www.eatonbalancing.com/2013/03/02/modifying-the-holley-teapot-four-barrel-carb-for-late-model-distributors/
If you’ve got hood clearance for the spacer, I’d be more inclined to look at the Summit carbs DLR mentioned. The annular booster are a really good street design.
B-rad
Posted 3 Years Ago
Posts: 348, Visits: 1.5K
I'm not sure what the later centrifugal and vacuum distributor is. And does it matter if the car is 6 volt or 12 as far as the distributor is concerned? I know I'll have to swap out the gear on the bottom of the dist shaft.
Btw, I just took the engine in to the machine shop to get cleaned and inspected. I was happy to see that he had another y block in the shop. At least I know he has some knowledge about older engines. He said the cylinders are going to be needing to be bored so it looks like I'll have a bigger engine when it's done
Brad
Sierra Vista Arizona
1954 Lincoln Capri
B-rad
Posted 3 Years Ago
Plus the carb wasn't with the car when I bought it and they're really expensive. Seems like a newer Holley would be a good option. It would be nice if I could find one that would fit the original air cleaner.
Brad
1954 Lincoln Capri
Posted 3 Years Ago
The early Holley “teapot” carb actually have the large 7+” air cleaner flange. Any new modern carb you buy will have this same flange. Depending on the air cleaners design there are spacers for the top of the 7+” flange in case you need one.
Ignitions don’t care whether they are 6 or 12 volts because the 12 volt ones need a ballast resistor to lower the voltage near 9 volts to stop the points from burning. If considering electronic …Pertronix has a 6 volt system.
Posted 3 Years Ago
DLR, it’s been a long time. Is the teapot that big? I thought it was closer to the 5 1/8” of modern carbs, just a lot taller with the float bowls up there.
Either way, look at the Summit carbs. Pretty reasonable $, and good on the street.
Posted 3 Years Ago
Miker.. with in a few months of buying my 56 292 I found a 57-up distributor and a 1953 Cadillac Carter WCFB. I installed them both with a small bracket I made for the Carter linkage; I wanted to use the stock air cleaner but couldn’t as the hole was way too big. I found an adapter in the stash I had of swap meet stuff and used it. Later I bought another air cleaner and gutted it so I could use it lower with a paper filter..
The early AFB’s were also 5-1/8” like the WCFB’s and Rochesters. The Holley including the teapots and Autolites were bigger at over 7”.
Posted 3 Years Ago
Thanks, DLR. one more thing to know I forgot over the last 20 years.
