Turn signal malfunction question '55 Thunderbird
Posted By Joe-JDC 3 Years Ago
Posted 3 Years Ago
Posts: 1.2K, Visits: 1.8K
Joe, you might find an answer here:rosecitythunderbirds.org
Joe-JDC
Posted 3 Years Ago
Posts: 772, Visits: 22.6K
The brake light and tail light work fine. Just not the rear turn signal portion.  Joe-JDC
Posted 3 Years Ago
Last Active: 1 hour ago
Posts: 4.6K, Visits: 38.5K
Check the grounds on the bulbs.
Joe-JDC
Posted 3 Years Ago
I am getting my '55 Thunderbird ready for the yearly state safety inspection and found the left rear turn signal not working.  The lights work, brake lights work, tag lights work, right turn signal works front and rear, but left turn signal front light comes on and stays on--no blinking, and left rear turn signal--nothing.  I have pulled the bulb and changed it, traced wires for any frayed or broken, none found.  Pulled the steering wheel and removed the turn signal switch to check it for proper actuation, seems to be ok. Flasher?  Ideas?   Joe-JDC
