Vacuum advance - how far should it advance at idle?
Posted By 56_Fairlane 5 Years Ago
Sandbird
Posted 5 Years Ago
Posts: 131, Visits: 542.7K
The '62 292 y-block distributor with mechanical advance curve appears to be rather wimpy compared to a '57 292 distributor with mechanical advance.
11 deg. @ 2000 for '62  @ dist
17-18 @ 2000 for  '57 @ dist.
Then you double it for at the crank
RB
Posted 5 Years Ago
Posts: 662, Visits: 16.7K
The 62 version would be more desirable to me.. That way you can give it 12-14 degrees of initial advance for a nice idle and throttle response and the 22 degrees in the distributor gets you right where you want to be for total timing
56_Fairlane
Posted 5 Years Ago
Posts: 575, Visits: 14.6K
Tedster (8/29/2021)
The mechanical timing curve is always sorted first, before connecting and messing with the vacuum advance.
Unfortunately I'm not sure how to check the mechanical advance. I recall there was a machine in my high school back in the late 70's that would check the advance. We were never shown how to use it.
Distributor Advance and Crankshaft Advance Are Not the Same!
~DJ~ AKA "Bleach"
Tedster
Posted 5 Years Ago
Posts: 513, Visits: 153.3K
It is very doable to use the engine itself as a kind of distributor machine for careful tuning. Basically just involves disconnecting and plugging the vacuum advance port, and then run the engine up through the RPM range and observe the mechanical ignition advance using a timing light. You can tell a fair bit as well about the mechanical ignition condition and timing set wear simply by looking at the way the numbers appear under the strobe, the way they react going up and down. A lot of the parts we use today are just plain worn out, a good "tight" serviceable distributor really makes a difference in how smoothly it runs.
Ford type distributors are not generally known for their ease of adjustment should it be necessary and Y-Block distributors in particular are not exactly conveniently located, back against the firewall like they are. So there's a lot to be said for avoiding the hassle and sending it off to be checked out and curved on a machine for the application intended. On the other hand it is very gratifying to have "done it yourself" and really learning a lot more about how a good sharp engine tune is achieved. As always the shop manuals and publications have the important details that are sometimes overlooked.
DANIEL TINDER
Posted 5 Years Ago
Posts: 1.8K, Visits: 154.6K
56_Fairlane (8/30/2021)
Tedster (8/29/2021)
I have the same machine (plus the tall manometer needed for accurate Loadomatic setup).  Good thing I also have the operator manuals, since it’s been so long since I used it, I will likely have to study them at length before calibrating another distributor!
6 VOLTS/POS. GRD. NW INDIANA
Posted 5 Years Ago
I’ve done mine with a dial back timing light and an extra person reading the tachometer as I dial back.  I usually find the max first. I don’t like dial backs for the most part, but they can work for this…
56_Fairlane
Posted 5 Years Ago
I have one these Maxi-tune analyzers plus a good old fashioned timing light that I've had for years. They've been the most useful tools for tune ups. The Maxi-tune was a gift from my best friend who passed away years ago.
Purchase VINTAGE RAC MAXI-TUNE DWELL TACHOMETER IGNITION ANALYZER TESTER-  ZERO ADJUST in El Cajon, California, United States
~DJ~ AKA "Bleach"
