Adding a brake booster to my front disc brakes on 57 tbird
Posted By RJ Palmer 4 Years Ago
RJ Palmer
Posted 4 Years Ago
Normally aspirated (48 reputation)Normally aspirated (48 reputation)Normally aspirated (48 reputation)Normally aspirated (48 reputation)Normally aspirated (48 reputation)Normally aspirated (48 reputation)Normally aspirated (48 reputation)Normally aspirated (48 reputation)Normally aspirated (48 reputation)
Posts: 17, Visits: 727
Thanks for your input Paul,  I too have the Granada front discs and dual master cylinder which I did 10 years ago. I'm not 100 % happy with that setup as I've had to make a few panic stops and thought car should have stopped sooner in that situation. I find that I have to pump the brakes  to get a good firm hard stop. Of course , in a panic situation I don't have that luxury.  I keep going back to Gil Baumgartner's comment where he stated to me in an email that disc brakes need approx. 1200 psi to be fully effective. I have talked to Master Power Brakes in No. Carolina and they recommend a 7" dia dual booster with a 1-1/8 " bore master cylinder for my application of front disc and rear drums. They also recommend a combination valve which I already have. I have already relocated the battery to the trunk to make room for the booster tank. Master Power has stated  that rework to the booster tank mount bracket will be required to ensure the booster tank does not contact the  tbird aluminium valve cover..I should have said the tbird under dash mount channel / firewall master cylinder mount will have to be  reworked.  So I'm going to go for it !  Thanks again  RJ Palmer
Posted 4 Years Ago
Posts: 1.8K, Visits: 306.3K
It sounds more likely you have a mis-match of parts and/or incorrect adjustment/system bleeding. That line pressure is generated by caliper style/piston size chosen, MC type, pedal ratio and amount of pressure you can put on the pedal. Power assist only makes it easier to achieve that brake line pressure. Factory cars also came through with manual disc/drum.
You have a GRANADA disc swap on your BIRD now? What size wheels?
Posted 4 Years Ago
I agree, pedal ratio makes a big difference. 6 to 1 and a MC of 7/8” or smaller normally do not need a booster. I remember my dads new 55 sunliner he had the dealer add a Bendix booster. It was a lot more sensitive than the 56 Victoria which he didn’t add one.
When I changed rear ends in my 56 the brakes came off a vehicle with power brakes and I changed the wheel cylinders to a smaller size. Also 4 piston or 6 piston calipers seem to work fine without one. There are a lot of options and opinions.
RJ Palmer
Posted 4 Years Ago
14" wheels
Posted 4 Years Ago
Posts: 1.2K, Visits: 1.8K
1st-gen. Mustangs/w 4-piston KH calipers had 14" rims.
Posted 4 Years Ago
Posts: 3.7K, Visits: 497.8K
Fortunately, I have had only one panic stop - doing 65 when I came over a rise and found traffic dead stopped in front.  Brakes worked very well.  I might add that I have a 9 inch rear with later TBird/truck brakes
RJ Palmer (4/23/2021)
FORD DEARBORN
Posted 4 Years Ago
Posts: 789, Visits: 113.4K
There is, in the case of a 65 Mercury Comet I'm helping restore,, a difference in pedal leverage if that vehicle was built with power breaks, or manual brakes.  That is, the MC push rod is positioned much higher on the brake pedal arm than if that vehicle was equipped with power brakes.  I just wanted to say there can be some not so obvious design differences.    Also, after a panic stop in my 64 F100 which has manual/drum brakes, a sound was produced I haven't heard in decades,-  screeching tires from hard braking.  Antilock brakes are the other piece of the modern brake equasion.  The truck stopped very well and straight with out incident and it doesn't take a lot of pedal pressure/effort with the stock design. Just some more food for thought....
Posted 4 Years Ago
14" wheels
What I am trying to find out is that you have a 57 BIRD w/ GRANADA front disc swap with what 14' wheels, original BIRD steel wheels or another wheel?
Your BIRD is not a dedicated restoration but a daily driver/resto-mod and has several upgrades?
Just curious.
