Possible fuel pump problem on 292 Y-block
Posted By zuburg 5 Years Ago
Tedster
Posted 5 Years Ago
Posts: 513, Visits: 153.3K
Just thinking out loud here - but there is some concern here about excessive cranking on a newly rebuilt engine? In this instance troubleshooting fuel pumps.
Maybe a strategy would be to rig up an outboard fuel tank (boat tank) or some type of gravity feed to the carburetor and get the 20 minute break-in accomplished, camshaft lobes and lifters "run in" and working together. Then work on the fuel pump issue.
Posted 5 Years Ago
Here's one designed to do exactly what Tedster describes.
https://www.amazon.com/Motion-Pro-08-0032-Auxiliary-Fuel/dp/B000WJ0RCA/ref=psdc_404763011_t4_B004NV42PQ
https://images-na.ssl-images-amazon.com/images/I/51MhAf6WfhL._AC_SL1000_.jpg
Joe-JDC
Posted 5 Years Ago
Last Active: 5 minutes ago
Posts: 792, Visits: 23.2K
I will go with "Just a bad fuel pump."  When I bought my '55  Thunderbird, it had an electric fuel pump in line to prime the carburetor before trying to start the engine.  I removed the electric pump, and the carb would not prime with the engine driven pump.  I replaced the fuel pump, and now it primes very quickly just cranking over.  The fuel pump diaphram rubber was softened by ethanol in the fuel to the point it would not create a vacuum.  Joe-JDC
