Visits: 498.2K
Ford 12 V wiring systems between 56 and the mid 60's's didn't change that much for charging systems until Ford went to alternators around 65. I had a 64 Fairlane, original equipment was a generator (last year for a generator). It was a 6 and I went to a V8 and changed to an alternator. The Fairlane club had an article with diagrams on what to do to make the change using various alternators (Ford and GM, maybe Mopar). I selected a 2 or 3G Ford (internal regulator) and used the diagrams, which were spot on. They should work for a 50's Ford. If you know some one who is in the Fairlane club the article is available from their website.
FORD DEARBORN
Last Active: 15 minutes ago
Visits: 113.5K
All good advice on upgrading the charging system. This Ford 3 wire 60 amp system works perfect. I don't have A/C or an electric fan but if I throw everything I have at it, it holds the battery at 13.5 min. volts at idle forever. If Ford had kept the Y-block in production just one more year, it would probably look something like this if keeping it in the family is important to you. The brackets are unaltered generator brackets but stuffing an A/C compressor in there will present a different challenge. When you get it worked out, post some pics.    Hope this helps and good luck. Edit post: Above voltage is 14.2 not 13.5
montana ford man
Visits: 23.9K
I read an article years ago about changing from generator to an altenator in a 56 ford. It said to use an early scrub pickup altenator as they are plentiful and not too expensive. I took the plug in out of a junked out pickup it has two wires ,the exciter wire goes to the ignition switch with a diode that keeps power going one way and not back through the switch so the engine will shut off when the key is turned off. Its been probably been 15 years or more and it still works fine.you can now buy brackets to mount it but doesnt take much to fab the generator brackets to fit.my generator light works as it should and the wiring is pretty simple.hope this helps,Im not very excited about mixing brand c parts but it isnt very obvious and works very well.
blockhead2
Visits: 6.5K
I have a NAPA 65 amp alternator that I put in my 59. Changed it out for a higher amperage one as I have AC and electric fan. It was OK cruising but marginal at idle with both on. I also have a used Mustang alternator, both of which I can sell you. I also have a 60 amp generNator if you want to keep the stock appearance. It is new that I would sell for less than cost at $350 plus shipping. If interested email me at wabate@verizon.net. Regards, Bill, 55 Tbird
Last Active: 4 days ago
Ernie, I’m not telling you what to get or whether it should look stock. Vintage Air in its instructions call for a 20 amp feed for their system so I’m assuming that will cover the clutch and fan. 1963 Ford Failanes still had a generator and factory air. I’ve talked a few owners and all said they did not have any charging shot coming.
Normal generators are 30 amp and some 40. This tells me unless you have a lot of accessories a 60 amp alternator will be fine. The CASCO kit is a 100amp and I’m waiting for mine to arrive to install it on my 56 Victoria. I don’t have air or any electrical high amp accessories. My wiring will be sufficient because I do not have any additional load.
If I add AC I will at least move to a #8 wire which is safe at 40 amps. Safe amperage for wire is #12=20, #10=30, #8=40, #6=50 etc. if their not in a loom they can always take more and this just my rule.
A standard 60amp 3wire wire be sufficient for most of us.
cokefirst
Visits: 2.4K
I am a fan of OE look. I find that the alternators used on newer vehicles (those in the 60's) don't seem to look right to me even when they re nicely installed. The Thunderbird conversion a few posts up is a great example. The alternator is as nicely installed as it can be but it does not match the era of the car. I am a big fan of the Powergen alternator that looks almost like the OE generator. I have them on 3 of my cars and I use the OE wiring harness and pass the wiring through the voltage regulator. The regulator must have some of the connections cut and is a dummy but I also get the ones that allow my dash {GEN} light to operate. These are pricey and not for everyone. If you are not a purist or close to it, it is much cheaper to put a new style alternator on your car. I have no financial interest in the Power Gen operation, but I plan on purchasing them for my entire fleet of Y block powered fords.
ErnieL
Visits: 9.0K
I guess I’ll go to the local parts house and start comparing alternators. Hopefully I’ll find a 10SI with a 2 3/8 pulley, if not we do some swapping. This IS a job to do. Not really something you want to be doing on a running car in the middle of cruisin’ season. Oh? What’s that? It’s 147 degrees outside? And Covid-19 will cause you to spontaneously combust if you leave the house without a mask on? Well, ok, we’re not missing much out there. All I did last night was kick a pan of Skydrol, then step in the spilled area, then watched it eat my $90.00 tennis shoes. Fekk! I hate dealing with A/C, so I took the melted shoes as a sign and called it a night. And then took the world’s nastiest hydraulic fluid to the hangar. :-/
56 Meteor 4 dr hardtop 56 Meteor 2 dr hardtop 55 Sunliner 53 Lincoln Capri 2 dr hardtop 58 Skyliner
Anna, Tx
Alternators usually come with a pulley which is too large to work best with a Y-Block damper. Get a pulley of about 2 3/8" diameter. The crank to alternator ratio needs to be about 3:1 for a street engine and 2 3/8" almost gets it there while not being too small for a v belt.
Daniel Jessup
Posts: 2.0K,
Visits: 131.2K
ErnieL
Visits: 9.0K
My Classic Air A/C came with a bracket for both the Sanden compressor and an alternator. They recommend a GM for simplicity, but either way, it’s no biggie.
Anna, Tx
