Visits: 340.0K
Thinking about it since they were cast a head with just different port arrangement keeping the shaft rocker system that makes sense. It wasn’t retrofitting a newer head.
Last Active: 2 Weeks Ago
Posts: 7.4K,
Visits: 205.0K
Visits: 285.6K
Ted. Why were stacked ports abandoned?
Last Active: 5 days ago
Visits: 21.3K
Looks like Windsor intakes and exhausts would bolt straight on.
Posts: 7.4K,
Visits: 205.0K
Florida_Phil (4/7/2020) Ted. Why were stacked ports abandoned?I can only guess at the reasons for the Argentina Ford engineers to convert the intake ports from stacked (Fase I) to being evenly spaced across the length of the head (Fase II). At the top of my list would be to get the two center exhaust valves away from each other. That would promote a more even distribution of heat in the cylinder head. It’s difficult to say if exhaust manifold life would be improved by evenly spacing the exhaust ports but add that to the list. Without a Fase II cylinder head to look at, it’s hard to determine from the pictures if there was a combustion chamber shape and head gasket change that eliminated the decks being part of the combustion chamber. If the head gasket became round to fit the cylinder bore, then that would be a positive. I don’t see any advantage with a firing order change but it could also be an underlying reason for the cylinder head change. There could have potentially been some negative advertising about the stacked ports by competing car manufacturers and rather than just replacing the Ford Y with another engine, it was more cost effective to simply redesign the heads. And it could have been that the Argentine engineers at Ford just wanted something different that they could claim as their own.
