Visits: 4.8K
Visits: 4.8K
I used 1.5 ohm Flamethrower as suggested by Pertronix My current MSD coil is .7 ohm Primary Resistance 4.5 Secondary Resistance Im not sure the stock Ford coil ohm rating
Posts: 7.5K,
Visits: 205.9K
What ohm rating is the coil? The Pertronix I modules do require using a 1.5 ohm coil while the Pertronix II modules require a 0.6 ohm coil. Using a 0.6 ohm coil with the Pertonix I module does have coil heating issues.
Visits: 4.8K
I know this has been done to death. But I don’t understand why Flamethrower coil fails. Their tech support say DO NOT USE EXTERNAL resistor. I have a 57 Tbird 312 running all stock. I do run an alternator. Output is about 14.28 volts. Holley 4160 4 barrel carb. I have pertronix ignitor 1 Module. The car runs well. A few years I installed a Flamethrower coil without external ballast as per instructions and tech support. The Flamethrower has an internal resistor. The engine performance was much better. Better throttle response from a stop, hardly any exhaust fumes and clean plugs indicating a much better burn. The problem is the coil without the resistor gets very hot and fails. If I run it with ballast resistor it will last but defeats the purpose. Is there a voltage loss to the plugs when using a ballast resistor? If so how much. I am currently using a MSD 45,000 V Blaster II with external resistor - again runs good but would probably get better performance without resistor.
The Brillman Company makes a coil EB30SS with 55,000 V that must be used with an external resistor maybe this is an option Any suggestions or help appreciated.
