Home
Explore
Latest
Popular
Calendar
Members
Who's On
Register
or
Login
Home
Keeping The Dream Alive!
Technical
312 heads on 239 cid y block
Posted By
ghancock
6 Years Ago
Post Reply
1
2
View
Flat Ascending
Flat Descending
Threaded
Options
Subscribe to topic
Print This Topic
Goto Topics Forum
ghancock
Posted 6 Years Ago
Visits: 41
Thanks!
Reply
Quote
Posted 6 Years Ago
As John points out, the ‘G’ heads were available on the 272’s and the only issue with running them on any Y engine would be when running the valve lift much higher than stock. By design, the intake valves on the Y-Block heads are positioned such that they will hit the cylinder walls thus preventing them from free dropping into the cylinders. While this has likely saved many an engine from catastrophic failure, this does limit the amount of amount of valve lift you can safely accommodate without taking appropriate corrective action.
For Y builds using oem iron heads, I use the 0.535” intake valve lift number as the maximum lift that can be used without having intake valve to cylinder wall clearance issues. Any intake valve lift values higher than that requires that the cylinders to be notched for intake valve clearance. Here’s a picture of what happens when you put too much lift where the cylinder has not been notched to accommodate it. That’s easily corrected by simply notching the cylinder walls appropriately. Just don’t notch too far down where the top ring rides in the cylinder bore.
And here’s a picture of the notch that alleviates the problem.
Reply
Quote
Post Reply
1
2
Back To Top
Explore
Home
Latest
Popular
Members
Moderators
Who's On
Tags
Search
Forums
Technical
Street
Racing
This n That
Classifieds
Stuff that fits
Jump To Page
Jump To Page
