distributor
Posted By blocky 7 Years Ago
Posts: 4.6K, Visits: 39.3K
It amazes me that any company would think that swap would work. Obviously they know nothing about the Y-Block distributor/oil pump configuration. Could this problem be solved with a longer oil pump drive if the gear location was changed to the right depth? I wonder how many "wrong" distributors they have sold and how many either failed or took out an engine. Sad
Posts: 1.2K, Visits: 285.6K
This issue was covered in detail in a previous thread.  Some re-builders are using small block Ford (289/302) distributor cores as substitutes for Y-Block distributors. I have seen one so far where the shaft was repinned.  The difference is in the distance from the mounting face of the distributor and the end of the drive gear.  This causes two potential issues. One is with the distributor gear and cam gear alignment.  The other is the short shaft does not allow the distributor gear to bottom out and ride on the block as it's suppose to.  These Frankenstein distributors may work for a time, then fail.
In my opinion, your best bet is to find a known 1957 and up Y-Block distributor and rebuild it yourself.  They are around, but are getting pricey.   I see them on EBay for $150-200.   Brand new distributors are available for big bucks.   Here is a photo I took of a real 1957 Ford Y-Block distributor and an incorrect small block rebuild sold as a Y-Block replacement.  As you can see, the shaft on the left distributor is 1/4" too short.  I purchased the incorrect distributor from Macs a few years ago.
http://forums.y-blocksforever.com/uploads/images/5eeab258-0500-49a7-8a7d-dd34.jpg
Robs36Ford
Posts: 93, Visits: 335.7K
A search on Google does not find any of these numbers.
It would be best to contact them for info: http://www.bosch-classic.com/en/internet/bosch_classic/ueber/bosch_classic___kontakt/bosch_classic___contact.html
1936 Ford 3W Coupe : 56 T-Bird 312, 47 Packard 3 speed, 40 juice brakes.
1968 Merc Cyclone FB GT 390, Getting a better front clip!
1977 Ford F-250 Supercab RWD Explorer Long box.
1976 Chev Camaro RS LT
Future rebuild : 1949 Ford F-1
blocky
Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)Supercharged (317 reputation)
Posts: 129, Visits: 2.9K
hi all some assistance is required. while going through the pile looking for  a y block dizzy i found one with a shorter shaft and want to know what it may suit . numbers are as follows. it is BOSCH. 9230063803. next.U-TFU8. NEXT    .ARDOOE-12127-C. CAN ANYONE PLEASE HELP??
