Jim Yergin
Visits: 53.5K
Not having much luck. I have replaced all of the spark plugs, the points and the condenser. I verified that the spark plug wires to #1 and #2 cylinders are not routed next to each other. I adjusted the valve lash. I inspected the valve springs and the push rods. They all appear OK. Still have the backfiring. Is it possible there is a problem in the spark plug wires? They are new but I have run out of things to check. Frustrating. Jim Yergin
Andy
Visits: 14.5K
If you have checked all the ignition and carburetor isn’t to lean pull the valve covers and check valve train. Look for a broken valve spring, bent pushrod , or possibly worn cam lobe .
emtdude56
Visits: 136
check your valve adjustment&valve train
Posts: 1.4K,
Visits: 179.6K
Jim, a faulty spark plug could occur with any brand name. Mine happened to be an original from the factory installed MotorCraft plug. The miss only occurred in the overdrive gear, and only when under load and pulling at lower rpms. Finally found the culprit with an oscilloscope mounted in the car out on the road duplicating the engine load condition. John's suggestion is equally as possible as the one you found in the Service bulletin. It's all about the parallel AND proximity routing of wires to plugs that fire in sequence. You have to know how the cylinders are numbered on the particular make and model of engine you are working on, though. Hope this helps!
Last Active: 32 minutes ago
Visits: 322.1K
Jim, if crossfiring was happening between 6 and 8, it could also happen between 1 and 2, one follows 2 in the firing order.
Jim Yergin
Visits: 53.5K
JLB, can’t thank you enough for the tip. I repositioned the spark plug wires and there was a big improvement. However there is still occasional backfire so there must be another problem. There is no solenoid/spark cut out in the T5. Over drive is just a fifth gear. Charlie, what brand of spark plugs solved your problem? Jim Yergin
Gene Purser
Visits: 6.0K
I'm glad to hear about the induction misfiring bulletin. I never would have figured that one out.
bergmanj
Visits: 3.9K
Jim,
THAT's the one [the TSB I was thinking about]!!!
Mentioning the O. D: There's a "spark-kill" circuit involved with O. D. "kick-down" & Solenoid I wonder if this may be involved due to O. D. relay points, solenoid points, other connections, chaffed primary spark wiring, etc. Might be worth a look, too!
Hope it helps you and others.
Posts: 1.4K,
Visits: 179.6K
Jim. Earlier in this thread you wrote: 'I have a T5 five speed in my car. The backfiring is worse when in 5th gear and revs are under 2000 rpm.'
I hope the spark plug wire routing of number 6 and 8 is responsible for your problem. Finding that service bulletin was GreaT. Another possibility to consider . . . I had a late model Ford that had a miss only in overdrive. The car had quality spark plugs which had less than half their 100,000 mile rating of use, BUT after checking out numerous other possibilities, the spark plugs were determined to be responsible!
Let us know what you find to be the problem.
Jim Yergin
Visits: 53.5K
Found this:
