I am really confused about the vacuum advance thing. I was always under the impression that vacuum advance aided the centrifugal advance, not added to it.  This means the cars are running 50 degrees advance with both working.  Makes no sense, but there you go.  I disconnected mine and the car runs fine without it.
They do work together though completely independent systems. Vacuum advance is strictly load based, while the distributor centrifugal weights and advance mechanism is strictly RPM based. Both systems are constantly adding in or taking out timing degrees depending on whatever the specific engine load and RPM combination are at any given moment, so they complement each other.
The only time the very highest levels of timing lead like that are seen is under very specific conditions as when steady cruising on level ground. Engine load is low. Engine will run a fair bit cooler with vacuum advance among other things, there's no good reason not to utilize it on a street driven car, it will only run better. The manufacturers in fact would have left it out altogether if it wasn't a good idea.
When cruising on the highway in high gear the timing is actually quite a bit retarded relative to optimum and will run hot. Fuel mixtures are relatively lean and take longer to ignite. Lots of ignition lead is beneficial under those specific conditions. The manifold vacuum is very high at this time, conveniently. It is an ingenious system. At the time it was the only way to get more timing pulled in under those conditions.
When we see things like "36 degrees mechanical timing" remember that's a number seen only at a bit higher RPM, cruising down the highway the mechanical advance timing will be a fair bit less. Lightly loaded, part throttle, lean fuel mixtures will tolerate relatively high levels of ignition advance. This also happens to improve fuel economy, maybe 15%, something like that. It is an interesting subject and widely misunderstood, plumbing a vacuum gauge into the cabin will go a long way to helping your tuning.
