1955 Thunderbird Fordomatic not shifting into high
Posted By Tater Salad 8 Years Ago
Tater Salad
Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)
Posts: 11, Visits: 744
Lou, I didn't get it up to 60 I thought it was revving too high at 35. Which was about 3200.
Yes Miker, that was my thought as well.
bergmanj
Posts: 257, Visits: 3.9K
The "plus" side to the oil coating from the road draft tube is that there's no rust on/in that portion of the frame on my '55 Crn Vic (engine and transmission are out right now due to issues with "knocking"; found-out that someone previous had not torqued-down the flex plate to crank flange bolts & it was "clacking around" on there). This is a "northern" car previously exposed to winter weather and salt way before me!
Regards, JLB
Posts: 3.8K, Visits: 33.4K
[quote]Tater Salad (10/9/2018)
Thanks Sandbird,
The kickdown linkage seemed right to me. (moved as the throttle linkage moved)
But I'm now having regrets about taking it out and not fully investigating all external factors. (shifter included)
The car had sat for so long my knee jerk reaction was to remove it and rebuild it. But I'll make sure those things are correct when it goes back in.
[/quote
It is unfortunate that You didn't as ask some Questions before pulling it. The Transmission Pressure Rod that goes down to the Transmission and  moves with the Throttle has to be adjusted to correct Length or it may not shift into High (third). This will occur if the Rod is too long . Pretty simple adjustment  to make from above with the Transmission installed. In the Transmission Manual there are checks and Adjustments to do before moving on to the Tests involving Air Pressure etc. One of them is setting up the Accelerator Linkage and adjusting the aforementioned TPS.
