Visits: 2.9K
I actually wouldn't use bar and chain oil. No, I've never actually read up on any chemicals in it. You can still buy non-detergent 30 weight. I did by accident this spring. I was changing the oil in my mom's mower, and picked up a bottle of STP SAE30 at Autozone About a month after changing it I looked at the bottle to discover it was non-detergent. All the new mowers today use regular detergent oil. So I changed it again.
Visits: 285.6K
Thanks for the feedback. My engine is coming home from the machine shop on Thursday. This is not my first engine build, but it's been a while. Lots of great tips on this forum. You guys are great! I do have one question. I like the idea of priming the oil pump with the heads off so you can view the oil flow to the heads. Did you make a special tool to turn the oil pump drive?
Visits: 2.9K
I used my cordless drill. You can buy an adapter that fits the drill with a square ratchet drive on the other end. I bought mine at Harbor Freight. Adapter for 1/4, 3/8, and 1/2 drive came as a set. I used my 1/4 drive socket set. 1/4in deep well socket with the longest extension I had. Hooked up to the adapter and drill. I did mine with everything together and valve covers off. You can see the oil coming out of the weep holes on the rockers. I turned the crank once in a while by hand and then ran drill some more. Remember, counter clockwise!
Visits: 112.0K
Florida_Phil (9/12/2018)
Thanks for the feedback. My engine is coming home from the machine shop on Thursday. This is not my first engine build, but it's been a while. Lots of great tips on this forum. You guys are great! I do have one question. I like the idea of priming the oil pump with the heads off so you can view the oil flow to the heads. Did you make a special tool to turn the oil pump drive? I have a tool that is designed just for that purpose. I've had it so many years I don't recall where I bought it, sorry. I'm sure a google search would find one.. https://www.npdlink.com/1948-1979-ford-truck/engine/oil-pump-parts/oil-pump-priming-tool
Visits: 497.8K
I use and ordinary speed wrench, a 3/8 to 1/4 drive adapter and extension and a 1/4 deep socket to prime. I works very well. I tape the socket to the extension so nothing gets lost. Remember to turn counter clock wise.
