Any Advice on this Oil Leak? [VIDEO]
Posted By Half-dude 8 Years Ago
Posts: 4.6K, Visits: 39.5K
After scraping brake kleen is pretty good for the remaining wet oil. Then you may be able to find exactly where the oil is coming from. Oil leaks can travel a ways before you find them.
Half-dude
Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)Supercharged (603 reputation)
Last Active: 7 Months Ago
Posts: 229, Visits: 11.3K
So am I basically out of luck until I do some cleaning? : /
Well I like to keep things on the cheap if I can, can I clean it myself with a scraper and such?
Posts: 1.9K, Visits: 195.0K
No offense intended, my bird was worse than that when I bought it. You need to find a guy with a lift and a steam cleaner, and clean everything off. Otherwise, you’ll never be able to chase anything down. If it’s still a road draft tube, consider a pcv system.
Joe 5bird7
Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)Supercharged (112 reputation)
Posts: 67, Visits: 2.8K
I'd start by cleaning the engine, at least on that side.  Seems to me it would be near impossible to find the leak(s) without cleaning all the existing oil off.
Half-dude
Problem Posted 8 Years Ago
So I've got a rather large oil leak on my Yblock that's been going on for awhile, but I finally got her up on ramps to try and track it down. Thing is she's had old oil coating the bottom of her engine ever since we got her so I dunno.
From what I can tell the oil seems to be sliding down the brim of the oil pan on only the drivers side, from around the oil sender, back to the bell housing and then dripping off that onto the ground. I was worried it was the infamous main seal leak for a long time since I could tell it was dripping from around where the engine and tranny connect but upon inspection it's coming from somewhere forwards of that.
Around the base of the oil sender is dry, and I don't THINK? It's the oil filter? It's hard to tell since the bottom lip of it is behind the lip of the oil pan.. if it is it's coming out RIGHT on the bottom of the filter where I can't see, could it be a bad oil pan gasket? Would the oil level be high enough in there to be flowing over the top? I guess the car is up on ramps so the incline could tip the oil in there towards the back pretty high. What do you guys think in your expert opinion?
