Visits: 609
This has been a good read. PF Arcand (1/8/2018)
Further, as I recall many early hydraulic lifter top ends tended sometimes to be troublesome, possibly because to the oils of the day. It's my understanding (but I stand to be corrected? ) that 1950s oils often contained paraffin which tended to promote sludge, particularly if oil changes & crankcase venting were neglected... In my understanding most of the issues were with shaft rockers being plugged and killing rocker assy's, which Y's were known for too. I know one of my 303 olds's is plumbed for oil from a galley up to the rocker shaft which was also a common kit for Y's of the era too. I guess i could see the lifters themselves getting plugged too
Last Active: 2 Weeks Ago
Visits: 113.5K
Greetings to all: I will attempt to pass on some information from a dear long time friend and I'm not great as expressing myself in text so please bare with me. Recently the subject was brought up regarding Ford"s reasoning for using solid lifters in the Y-block to which Ted and others brought up several very good points. After reading those posts I Immediately picked up the phone and called my good friend to pose the same question. My friend is probably one of the few surviving engineers directly involved in the Y-block development program still in good health, spirits and active in the automotive hobby. He also very fondly remembers several of the engineers mentioned in the Eichman book. While I am old enough to fondy remember the Y when it was introduced in 54, I was, at that time, too young for automotive employment. So I'll try describing the points from 65 years ago my friend remembered along with a few other interesting procedures employed in the experimental and dyno lab. It sounded like it was a deliberate intention to stay with solids for the Ford Y, not just for the cost factor, buy rather to keep the valve train light, to mention a few. It was determined the Y valve train was a very good stable and proven design. Rocker adjustments common in the day, were indeed attempted to be eliminated by developing, on the Y, 0 lash rockers. That is, a rocker fitted with a spring loaded eccentric to "wedge" into the rodker-to-valve stem space. It was very difficult working out the problems to make this mechanism reliable. Evidently it did work good, but not for long until the mechanism failed or wedged in too far preventing valves from seating. 0 lash rockers were abandoned as far as the Ford Y was concerned. (I believe Ford did equip some 6 cylinder engines around 1960? with these special rockers though.) It was also explained how technicians in the lab became very proficient at changing cams and lifters without turning the engine upside down. Most of us have or are aware of using clothespins to retain the lifters up into their bores so the cam can be removed and replaced. To remove the lifters, a tray was fabricated such that would allow it to be inserted into the cam tunnel, then releasing the clothespins from above, allowing the lifters to fall into the tray. If it was important to match each lifter to it's lobe, then one lifter was released and withdrawn at a time. To install, one lifter was placed horizontally? on the tray "hooked" to a rod like device that allowed the technician to manipulate it while being sighted from above, then fished up into it's bore with a magnet. Since a lifer is taller than a cam journal, my mind is running high gear thinking of this "hook" device because my friend could not remember the exact details or it. Hmmm, wish I now had a block sitting in the garage to test this method. If anything, this may be some food for thought. I hope my text is comprehensible and all Y Guys find it as interesting as I have. Please keep in mind this information is from someone's memory of 65+ years ago and is not, as of yet, my experiences. Thanks for reading, JEFF.........................
Posts: 3.3K,
Visits: 238.8K
Another possible factor is while the Ford Y-Block was introduced in 1954 (in the U.S.A) I read that they wanted to get it into production for the company's 50th anniversory in '53, but it didn't happen one way or the other. The point is the design pre dated that other unmentionable engine by more than it appears..
