4 Barrel intake differences
Posted By PF Arcand 9 Years Ago
Brent (10/10/2018)
In lieu of dimpling the plenum which is thin, could something be added/attached to the BT plenum to achieve desired result?
I'm always hesitant to mechanically attach anything within a plenum as it can come loose.  I think any dimpling or channeling that’s limited to a maximum of 0.060”-0.080” would be sufficient.  I used a ¼” ball mill and to obtain the full radius from the end mill, the depth would only need to be a maximum of 0.125” or half the diameter of the end mill.  I went to the extreme on that test as I was looking for a make or break result.  Smaller channels or dimples should prove to be just as adequate in making the desired turbulence.
