Intake heat passage
Posted By paul2748 8 Years Ago
Thoughts on completely blocking off the heat crossover; If you drive in northern latitudes other than right in summer, carburetor icing could be a problem.
It doesn't have to be freezing out to have carb icing, due to venturie air velocity. And if the exhaust manifold divertor is disabled  & the crossover completely blocked, isn't it going to at least partly disable your chokes operation? (assuming the choke isn't electric)  Unless it's a race engine, the truck semi closed gaskets might be a better idea ?
2721955meteor
Posts: 927, Visits: 190.0K
PF Arcand (3/29/2018)
truck int gaskets ar restricted by 50% and are usually in oh kits
