Holley 1848-1 problem
Posted By oldcarmark 8 Years Ago
Those 2 Slot Head were my doing. Missing when I got it.
Talkwrench
Posts: 898, Visits: 23.2K
Ahhh bugger! Unsure
Yeah but at least now I know why it would not work properly. I still think this was assembled wrong at Holley. Why would anyone swap the base on a brand new Carb?.
Nothing to be gained. Throttle bores are the same Size. Who knows?.
Last Active: 9 hours ago
Based on the pictures you provided, this doesn’t look like a Holley blunder with the slotted screws that are in place.  While it’s possible someone was trying to make this carb have a vacuum port, it’s more likely that the original base plate went on a different carb so that the Ford linkage would be more compatible on that other carb.  You don’t show the linkage side of your particular carb but that might help to shed some more light on what you have and why it ended up this way.
http://forums.y-blocksforever.com/uploads/images/31277010-7d71-4bda-8b49-52fc.jpgThe Slotted Screws are from my old Teapot. This Carb was missing 2 and the Teapot Ones are same TPI and just a little shorter. If this was someones Handiwork why not put it back together as it wont work with this Base? Complete waste of a new Carb by not doing so.The Linkage on the other Side is the same as what comes on the 8007 390. I trimmed off part of the Linkage using a Dremel to use the Rod and retaining Clip  type on my Ford. The correct 1848-1 Base has a Triangle shape Lever which apparently is designed to use on a Ford.
Y block Billy
Posts: 1.6K, Visits: 5.2K
I also just had a 57 bird come in with one of these 1848 carbs on it and am going through it now, question? how much should the secondary blades be open? and it is also missing 2 screws in the base and I checked another one laying around and it also is missing the same 2 screws, did they normaally come without those?
55 Vicky & customline
