RPM drop when turning on lights???
Posted By ianmatt 10 Years Ago
2721955meteor
Posted 10 Years Ago
Posts: 927, Visits: 190.0K
you sead the battery is from a rv,is it the house battery ,if so it should be a deep cycle that being the case that is the first thing to change. deep cycle batterys ar intended for long periods of low draw,not recomended for car or truck. a deep cycle takes longer to charge and after starting  the truck for tests  alternator sences low charge and load the engine at idea..
Talkwrench
Posted 10 Years Ago
Posts: 898, Visits: 23.2K
Your Pertronix unit wont like low voltage.. If your electrical system is sad then you turn your lights on lowering the voltage more ... well ?
Posted 10 Years Ago
Posts: 3.7K, Visits: 498.3K
Check the output of the charging system by using a multi-meter or similar and checking voltage output at the battery.  Around 1500-2000 rpm's an alternator should be putting out 13.7 to 14.5 volts.  At regular idle it may be a little lower.
ianmatt
Posted 10 Years Ago
Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)
Posts: 96, Visits: 443
I tried checking all grounds and ran a new ground from intake to cab just to have extra. seemed to help a tad. The battery has a cold crank of 550. Thats low right? I drove the truck to work today so i can go grab a pic of the battery if you guys want.
Posted 10 Years Ago
think you can fit a battery with more cca.  However, if the engine starts, then the battery is not a problem in that respect.  I wouldn't spend money on a battery simply because of that.
If the grounds check out okay, make sure all of the connections are good, no corrosion frayed wires, etc.  Once that is verified, start your troubleshooting of the battery and charging system.
Talkwrench
Posted 10 Years Ago
550 CCA  should be fine
2721955meteor
Posted 10 Years Ago
ianmatt (11/23/2016)
not so charley,a deep cycle will start the engine but will show low charg after heavy load, as deep cycle ar desighned to run a rv furnace all night etc,not desighned for a car or truck. example if you try and charge a deep  with a regular car battery the alt will sence  full charge befor the deep cycle is charged and cut out. the chart to min.. another example in real cold weather deep cycle will fail to turn the engine fast enough to started amp -25 etc.
