Vintage Style Air Cleaners for dual teapots
Posted By gritsngumbo 9 Years Ago
30 coupe
Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)Supercharged (312 reputation)
Posts: 130, Visits: 3.4K
DryLakesRacer, thanks for your reply. I really wanted one of the original chrome oval air cleaner assembly's that came on some of the Thunderbirds, but was unable to find one. when I found out how much they sell for I backed up. I then found a source for one like it only in cast Aluminum. It was priced at $750. It also weighed about 2-5 lbs.  . Well, I can not justify that for a reproduction, for my hot rod. If I was restoring a Thunderbird that would be a different matter. call me cheap if you want . If I could find one of the original chrome oval ones at that price I may consider it, but I would have to think about it. like I said in a previous post, I will probably end up making  something.
I feel your pain. I'm lucky and unlucky that I used small base Carter WCFB's on mine. Lucky as they were something I knew, unlucky the top was also smaller than the norm today and if I wanted to show them off I needed to step up for repo Corvettes which are 200 a piece or more for originals. One option you may have is I saw a dual quad air cleaner unit for the bigger tops and the bottom was adjustable to fit any carbs center. It had a finned oval top and an exposed air filter. It may need a thicker filter for your app because of the way the teapots are made. Next time I'm at that speed shop I'll get the brand, cost, and a photo. Good luck.
Posts: 1.9K, Visits: 194.9K
30coupe
I don't know if this will help but I bought this a/c top for a tri power I took off. Never used it. At least 15 years ago. It's an O'brien Truckers in the original 15" version. This link shows the current version at 18".
The base is your problem to fab. Then the flat plate is drilled as needed to go on the element, and the finned cover bolts to the top plate. The finned cover is nominally 15 1/2" by 7 1/2".
If you can make it work, I'll make you a deal you won't believe.
Link
https://www.obrientruckers.com/ecom/product/239/2391/
Rono
Posts: 1.3K, Visits: 80.0K
Here is another option that might work for your Teapots. I am running dual Edlebrock 500 cfm carbs on an Edlebrock #257 intake and the Mooneyes dual quad billet air cleaner worked out well. Not dirt cheap, but reasonable compared to some others.
www.mooneyesusa.com/product-p/mp715.htm
Rono
30 coupe
Thanks guy's I am really looking for 2 separate  air cleaners and not an oval, but I may consider one.   Miker, let me think about it a bit on the oval. you can e-mail me if you like. I think you have my e-mail.  Pm me if not.---Jim
Pm sent
