Starting problems from my update of the 57 intake manifold?
Posted By mgcookwv 9 Years Ago
Fty6Vic
Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)
Posts: 10, Visits: 54
It sounds like there might be a problem with the power valve in the carburetor or the vacuum passage that operates the power valve. The reason I'm saying this, I've had it happen with a  rebuilt engine and a new Holley Carb. I thought I might have screwed up the cam timing. After a few hours, I took the Carb off another car and used it. Everything was fine after that.
