Visits: 5.0K
Yes , the car has it's original Dana 44 rear.
Visits: 1.3K
Nice Job Petew!!!
Visits: 274
Hello can you please tell me what I will be needing for parts list for this conversion, I have the 57 bird with auto now, Looking for my pedal assembly not sure what else I will need exactly. What about speedo hook up? Thanks, Gary
Visits: 5.0K
You will need A T-5 from a mustang 5.0 prior to 1994 An adapter from John Mummert , his website will tell you what specific year T-5 transmission will work A manual transmission bellhousing for a Y block car not truck. A pedal assembly from a 55-57 bird. A Y block throw out bearing fork The linkage that connects the clutch pedal to the throw out bearing fork Y block manual transmission flywheel Clutch , pressure plate and throw out bearing, all of which I bought from Mummert at a very reasonable price. Use a diaphragm style pressure plate lot less pedal pressure. A T-5 , AOD or C4 yoke for the drive shaft A new drive shaft, I used one from a mid year Corvette that worked fine , Just something I happened to have in the shop. You will need to build a cap for the top of your tunnel where the shifter pokes through . Speedo cable I used was from a 1957 Ford. A 21 tooth speedo gear . A 5.0 mustang transmission mount, some modification to the stock trans cross member , T-5 mount will require drop of about 3/4" Those are the things I can think of off the top of my head.
Visits: 5.0K
Oh and don't forget to connect the wires from neutral switch or the car won't start. Some T-5's have a neutral safety switch some don't . Mine didn't so I just spliced mine together.
Visits: 78.1K
Will also need the plate for a manual shift vehicle that goes around the steering column. It allows the clutch pedal rod to pass thru the firewall.
As mentioned there are clutch rods, a "Z" bar and the pivot balls that attach to the frame and the engine block allowing the Z bar to rotate.
Oldmics
Visits: 5.0K
Right you are sir.
Visits: 5.4K
That is impressive.
Visits: 780
Peter, Very nice work! WLJ
Visits: 274
Peter, Thank you for taking the time to assist me. Very much appreciate what you have done, Now to locate bell housing and pedals. Been on this 5 yrs now starting to see some daylight.
Gary
