Riz
Visits: 4.4K
I run 3x Holley 94s on mine as well. Set up is same as others progressive linkage, outer idle circuits and PV blocked, larger jets on the outers. I run an Offy 3x2, I know there are much better, but I got mine for $75 at a swap meet and figure I will run it until I find a better that does not have bubblegum welds on it and helicoils in every stud mount for $1000 on e-bay.
Mike Rizzo
1963 F100 "Rudy"
Daniel Island, SC
Apparently Fords were not the only manifold Offenhauser made with poor characteristics. There is a shop showing what is done to the Buick nailhead Offy to make major improvements in its flow. My Offy was a gift from a friend so that's why I built it and using Rochester 2GC's was something I wanted try, too bad I never got the chance to run it. Like dual quads, 3-2's makes any engine look better. Good Luck....
Posts: 1.4K,
Visits: 179.6K
NICE, Riz. Looks very professionally done. -And for real world driving, I'd be HAPPY to have it sitting under my hood ready to have the key turned for a ride!  Sometimes we can get lost in the enlightening in-depth information we're able to obtain from our fellow enthusiasts. Considering how and where I drive my car on the street and highway, I would probably never feel a difference between driving with a properly sorted-out 3x2 Offenhauser or an Edelbrock 357 set-up. You've sorted out a 3x2 set-up with progressive throttle linkage, sourced three carbs that work together, worked through determining and executing needed jetting changes, AND knew to eliminate the power valves and idle circuits on the end carbs... I'm sure that what you've assembled is very drive-able and enjoyable. I expect you've gotten enormous self-satisfaction compared to what many owners back-in-the-day likely experienced. What you've done is more than many before us knew to do when they bolted three mismatched 'found' carbs on an intake manifold, cobbled together some mishmash collection of salvage yard sourced throttle linkage pieces, and went for a ride down the main street in town. Kudos, Riz!
Riz
Visits: 4.4K
Thanks- A lot of ideas and help from the guys on this forum. For me the old school hot ridding is more fun than the extra few HP that could be wrung out with some more modern kit. Some of the parts are from Charlie at Vintage Speed-most are cobbled together from the bolt bin. As much as I don't like purpose built rat rods- The debris screens for the velocity stacks are actually stainless sink strainers. Best compliment ever came unexpectedly-he appreciated the old school shade tree mechanic and the fact I saved the original engine.
Mike Rizzo
1963 F100 "Rudy"
Daniel Island, SC
Riz
Visits: 4.4K
Just reread that-didn't mean to sound cocky at all-was intending that if any of us were after big HP we probably wouldn't be messing with the Y- probably just go with a crate 350 (gasp) Most of the fun is taking a project and making it unique and individual, so run mismatched parts if they work and make it fun.
Mike Rizzo
1963 F100 "Rudy"
Daniel Island, SC
carl
Visits: 20.6K
Looks like you were at the Zoo car show Mike,we had the 56 there also,i think they had around 1000 cars this year Carl
Riz
Visits: 4.4K
Yeah was at the C-bus zoo, my truck was parked back in a dark corner (not a show truck) I guess it was the path Chip walked to and from the paddock. Got to shoot the breeze with him for a while, was very down to earth. We will have to hook up at this years.
Mike Rizzo
1963 F100 "Rudy"
Daniel Island, SC
Visits: 497.8K
Isn't Charlie Pride the Country & Western singer ??? LOL paul2748 (12/26/2015)
Wthout knowing what the Ford carb is, you can run the smaller in the middle. I assume you want to run progressive linkage. In my opinion, in the situation you have I would run the same carbs front and back with the middle being the odd one If the odd one is smaller, might be better gas mileage for normal driving. Unless your wife is a hot rodder or wants the 3x2's, I would go for a 4BBL. The only guy I know that can set everything up is Charley Price in Florida. Some swear by him and otgher swear at him. I friend of mine used him and is happy with his work so far, but hasn't really ran them.
hdshadpar
Visits: 543
Tks everyone for the info, got a hold of Charlie and he will look after the trip pack. I totally understand as well that the 4 barrel is a better option but we are going for the look under the hood and not that much performance. However that is plan A but we know how plans can change.....
Don't grow up, it's a TRICK!
30 coupe
Visits: 3.4K
Airman, are you using progressive or straight linkage on your tri-power set - up ?
